bigwalton's Postal Stroker
Didn't get as far as I'd hoped last night, ordered the wrong fitting for the input to the regulator and want to have that on before I cut hose for it.
I did modify the stainless line that I plan to use for the return. Trying to keep the rail as cool as possible and going in the rear fitting with the supply, then out through the stainless line to the regulator and back to the tank.
I cut the 90° bend off the line and put a 3/8" compression-to AN-6 fitting on it, then going to a 90° AN swivel, this allows me to have free rein on the direction of the 90 and I think I have it positioned where it will work between the rail and throttle body and clear the throttle cable bracket. There's an unused M6x1.0 threaded hole in the intake almost directly under the stainless line in this spot and I ordered some all-thread studs, unions and button head screws to make a standoff that will have a clamp on top to go around the line and the DEI heat shield to support this end nicely. You can see a socket head screw in the hole I'm talking about in the overall pic. Heat shield will work fine, just need to trim off about 6" and plan to heat shrink it to the end near the fuel rail to keep things looking neat.
Got the return line done from the regulator to the tank, left some extra line on it to cut/pull/splice the line should anyting ever happen along the rail, just need to get a clamp on it.
Got some AN-8 line "spacers" off Amazon (for some reason the AN-6 line clamp dimensions all seemed way too small and would really crush the line), and it fits great. Planning to drill them through and put longer bolts into them to go through to the frame rail instead of the PITA stainless cushion clamps I have there now. May end up getting a few more of them now that I know they work well to do some other mounting (firewall above valve cover and I have an idea for where the fuel lines pass over the rear shock mount)
Rest of the fittings come today, out of town this weekend and have to mow tonight... cooler weather, grass now thinks it's hay or something.
Oh, and hoping the vent box drain will be able to be heated/reshaped and still fit on the outlet, otherwise I'll have to sort out some other idea there.
Finally got back out on this thing again.
Happy accident, bought yet another incorrect fitting for the regulator but it made me look up the instructions for the regulator to confirm the port size. Reading them I realized I was trying to run the feed from the rail to the regulator on the wrong port. :banghead:
The first “wrong” fitting I bought turned out to be correct for the port I should have been using but I was now short one 90 degree swivel AN6 fitting. Got that ordered and moved on to other things.
Looking for a tool, I picked up a box and realized it was a fun bit I could swap on. When I got the tank/skid and access port for the bed, Genright was having a sale and the “you may also like” got me. :huh:
Overdrive “vented” power steering pulley. I thought this would help with the ram assist and they got me with the blingy blue. :shrug:
The ribs are angled, I figured it couldn’t hurt.
That will give you more power when driving forward from the additional "thrust".
Pausing for an update, been at it all day for once! Got the fuel lines finished out. Want to get back under it here yet tonight to finish clamping and mounting them to the frame rail.
Pump - filter - rail - regulator - tank
Debating how to brace the length of the stainless return line. Have two or three options. Want to have the wiring/throttle cable/throttle pressure cable mounted before I finalize that.
Got the stroker set up for the newer alternator like I had before and mounted the compressor. Compressor mount and bolts fought me, ended up having to tap everything out and chase the bolt threads.
Looks like I need a shorter serp belt and I guess I should go ahead and upgrade the alternator “while I’m at it” 🙄
Think the fuel system is ready to test. I got some dual aluminum clamps off Amazon and through-drilled some of them out to fit bolts for the threaded holes in the rail.
Made up a clamp setup for the return line. Got some stainless 6mm threaded rod, coupling and screw to use in an open hole in the intake to make a standoff and made up a fairly crude clamp out of some sheet metal I had on the shelf. Will probably tweak this before its final, but good enough for now, bugged me to have it just hanging off the fitting on the front end of the fuel rail.
Pulled a block plug out of the side of the block to relocate the Speedhut temp sender. Always bugged me how I had it rigged into the heater hose before.
You just had to post that pic of the fuel line with the writing upside down for us OCD'ers @spankrjs, is that a Postal thing :unsure:
Besides that your progress is making me jealous. :thumbsup:
Long weekend of work on the postal thanks to Steve aka @Rusty6 who came up to lend a hand.
Manifolds installed with a Newcomer Racing reusable copper gasket and stainless stud washer kit minus one bolt where the header hit. Injectors in. Fuel system tested and weeping plugs in the regulator fixed, so it’s ready to go.
Started matching up and routing the wiring from the engine harness to the Terminator Max. Battery back in and made up a board to mount the maxi fuse holders that are part of the wiring kit. Plan to make a plastic version eventually when I have all the wiring and mounting sorted.
Made a temporary mounting board for the ECU, ignition control box and coil to get the engine broken in without spending more time on trying to perfect mounting/wiring everything, going to terminate all the wires with simple spades at their full lengths for now. Will throw the radiator on and hook it up for break in.
Hyperspark dizzy in and phased, marked for #1 terminal. Need to make up the plug wires.
Had to source a shorter serpentine belt to match up to what I have going on. Getting that on seemed momentous for some reason.
Similarly mounted the oba manifold much more cleanly than it was before and that made me happy.
Easily the most that’s happened on this in one go, thanks Steve!
Big day. Kate decided the engine needed to be in and so it was.
Swapped in the MORE motor mounts with Kate between the frame rails.
Our ACE had heavy grade 8 washers, so I got them and ground them to fit each spot on the mounts. Didn’t get a pic of the other side.
View attachment 123030View attachment 123032View attachment 123033View attachment 123034
She’s in. Next up is fuel lines and fuel pressure regulator, then getting the electrical done on the engine side enough to get it to fire.
@bigwalton
Eric, Question for you on this? I was reading on one of the stroker builder sites that they recommend using different engine block plates for the engine mounts, especially on the driver's side due to the increased torque. The discussion was around adding more than the factory 2/3 bolts to distribute the forces and reduce the risk of cracking the block.
Did you use the factory CJ 4.2 block plate drilled out for the 4.0 on the driver's side?
Never came across anything like that. I used whatever I had for the 4.0. I don’t remember drilling anything out. (Yes, I know there's a metric bolt, but I thought it was just a thread difference, I don't recall having to drill for it.)
Got a link? What alternative would there be?
One hole on the driver side of the 4.0 block is a metric bolt that is bigger than the stock 258 3/8" block bolts. You need to slightly enlarge one hole in the block plate and use the metric bolt.
It might depend on the block. I had to do this for the 4.0 block that is in the red Scrambler when I swapped out the 258.
Post #1,410 on red Scrambler thread. Rear most hole on the driver side used a metric bolt.
I remember that it's metric, not that I had to drill the mount, but it's been a long time and a lot of bourbon ago. I simply pulled what was on my 4.0 and put them on this.
so, this is an example of why this forum is amazing. If I was doing something like this, on my own, what are the chances I would figure this out?? I'd probably struggle for hours wondering what was wrong with the hole or bolt and the drill it out to 7/16 or 1/2 only to regret it later.
So, some yahoo on CJ-8.com shared the below when he swapped a 4.0 into his Postal years ago. 🤣
His thread has been an extremely helpful guide as I work through my stroker install.
This is what I used to get my stroker onto the engine cradle. My rearmost hole was not threaded as far as I could tell, so I drilled it and tapped it for 1/2-20.
It sounds like the consensus amongst our group is run it with the factory CJ engine plates. It's interesting that the bomb proof mounts only mount with 2 bolts each to the block.
