Found what i think is a nice solution for my bigger connections with a fuse box mounted on the battery itself using a bit of copper bar and a clamp with a stud on it.
Bent a bit more copper bar to act as a ground bar, drilled and tapped it thus solving a lot of issues i thought i had keeping this wiring tidy.
Hung an ignition relay on the bar as well to power the fuse box on the other side, i didn't want to risk overloading the standard ignition switch as i have absolutely no idea at all what its rated at...
There is a lid there that covers the fuse box and i will sort out and tidy the rats nest of wires properly later on when the final build happens including lengthening that cable that crosses the battery, that short cable is really annoying me quite a lot for some reason.
