- Biloxi
- MS
This is not one of the major repairs I need to do, but I have been needing to fix my windshield wiper linkage for a long time. I have an aftermarket WS frame and the wiper pivot holes are slightly off. I have been running used OEM linkage and pivots and it has been holding up OK due to me slotting out the mounting holes in the wiper motor itself. But, you can see in some of the above pictures that my driver side wiper arm is bent due to over extending, getting bound up, and having to reach out the window to push linkage back up. After trying to clean bugs off the glass with shitty wipers finally fixed them.
Bought these parts from the GA swap meet a few years back, finally installed them. They are/were available on eBay, too.
Two adjustable linkage arms, a spacer, and some lubricant.
Compared to stock:
You will need two driver side pivots, I purchased two aftermarket pivots, two OEM driver side pivots will work, too. And THREE of these little clips!!
I tightened down my motor, installed and tested short arm first, removed it, installed and adjusted long arm next. So, long arm first, spacer and clip on passenger side pivot, then short arm and clip(s) - one on arm to motor link and the other on driver side pivot. It took me longer to find a third little clip in the parts stash than it did for me to adjust/install the linkage!!
Quick picture of driver side pivot: long arm then short arm then clip.
So far seems to be working great!!!!
Compared to stock:
