Thrust washer installed. I used some of the transmission assembly lube to hold the little peg in place. Bearing ready to press on.
Pressing the rear bearing on. Note that the retainer clip groove on the bearing faces the REAR of the shaft.
Fifth gear and it's corresponding clip are up next. Note the directions this gear goes on. (Not sure if it is correct in below picture)
Pressing 5th gear on to the main shaft.
Installed the snap ring, it is a tad loose. (needs to be a hair fatter)
My original locking ring was an "H". It measured in at 3.12mm. I can probably jam a "K" in there, maybe. To be safe, I ordered an "I" and a "K" from Toyota. So, waiting on parts....
A few random notes I took while installing all of these parts. I checked the clearances as directed by the FSM.
First and second gear clearances:
2nd gear a hair looser then first, but still within the specifications.
The new 3rd gear clearance:
Brand new gear, tight clearance. Kind of neat to see how the thrust faces of the gears do actually wear with use. Once they get too loose, unfortunately, time for a new gear, no way to shim them.
My transmission worked perfect before I took it apart, no complaints at all, sure hope it still does when I'm finished!!
My original bearings were still tight, but I did change them. All my brass blocking rings were still in great shape, side "teeth" and the little "brake ridges" on the inside of them.
So, besides the input shaft that was damaged due to pilot bearing/bushing issues, and me chipping 3rd gear, no damage or abnormal wear inside this transmission. It was new when I bought it, I put 70,000+ miles on it, no complaints. I have not really abused the transmission, but I do use this Jeep, probably harder then a lot of people. Besides off road use, it was nothing for me to drive this Scrambler for 12 plus hours straight on the interstate. All in all, it was a good choice. If not for the input shaft issues, I would say that this transmission would have easily lasted me at least 200k miles before needing a rebuild. A much needed upgrade over the T5's I had in here.
So, waiting on some lock rings. Assembled parts out of the way inside the new work bench for safe keeping:
Parts table a little lighter!!!
A few quick notes:
1) I am lightly lubing all parts with the Valvoline MTL I have been and will continue to use inside this transmission. It is yellow metal safe, and must be doing a great job, no complaints. Note the word "lightly" lubing. Don't get carried away, you still have to glue the cases to the center slab. You don't want excess lube dripping into your sealant before it cures!!!
2) I have been using the press to install these parts. Mine is just 12 tons, seems more then adequate. I am lubing all the pressure contact surfaces before pressing the parts together. Everything pressed on just fine, no problems or excessive force needed. I would say it has been easier to reassemble then disassemble.
3) Hopefully, after all this trouble and time, this damn thing works perfectly!!! If not, I'll throw the T176 back in this Scrambler and learn to drive slower LOL. I never did have any issues out of the T176........
That's it for now.
