So, parts update.
Picked up the C3085 kit from O'Reilly's late yesterday. Old box, beat up, unsure about a few things.
One good sign!!
Cam gear part number:
Crank shaft part number:
No part number on the chain, single black link:
And installed:
Maximum 1/4" deflection, so happy with that.
BUT........
A few things concern me about this particular set:
1) It was previously installed, note white paint
2) Looks like it is used, note wear to teeth and hub face of gears where they press against crank/camshaft
3) Chain not having a part number doesn't necessarily concern me, it looks new, suppliers do have running changes. I have noted some pictures of the Mopar set having this black link. In all probability Cloyes makes the Mopar set, probably OEM supplier.
But, I'm just not convinced this is all a new/matching set, I just can't install it. I will be running over to Pensacola, Florida, later today to pick up another new Cloyes C3085 from a different O'Reillys. Only about a 1.5 hour drive, so not terrible. By doing this, hopefully I can start putting this engine back together tonight, vs losing this whole weekend waiting on mail ordered parts. I am going to exchange this one for their new one, if it looks better.
I talked to Lee at Hesco, he recommended the Cloyes 9-3127 kit, which is a true double roller kit. He thought that was what was installed, but it was not. He also said that they do not install the rubber chain snubber. I don't think I am, either. All it can do is cause rubber debris to get scattered into the oil. I might just finish "machining" off the cast rubber snubber brackets from the original timing chain cover and reinstall it.
Regardless, I ordered one of these fancy Cloyes 9-3127 timing sets off Amazon, there was a "new in open box" one available for $130.00. Future spare. The interesting thing about the 9-3127 Cloyes set: it fits all CJ-7 4.2s 1976 - 1986, all Wrangler 4.2's, and all Wrangler 4.0's 1991-1998.
This tells me something was not correct with the "silent chain" kits I purchased, since it looks like any of these timing sets should be interchangeable over a wide year pattern?
The other interesting thing about the Cloyes 9-3127: you can have the manufacturer make them "undersize", .005 or .010, to better fit modified engines.
So, hopefully pick up a "better shape" C3085 kit today, get back to work on this engine this weekend. If not, waiting until Monday for my Amazon delivery.
That's it for now.
