- Biloxi
- MS
Decided to tackle one last project I have been meaning to do for the last 10 years - install extended bump stops for the suspension. I have been using the stock bump stops, which are way too short. I have not damaged any shocks, yet, from not having the correct length bump stops, since most of the time when I bottom out a shock it is at low speeds. However, still not a good idea to use the shocks as bump stops. Also, my springs have sagged a good bit, so the correct length bump stops will prevent some not so minor tire/sheet metal contact.
Of course, no one makes bolt on longer CJ bump stops anymore, that I could find. I purchased the following, made for the front end of a YJ Wrangler, KJ09120BK:
www.daystarweb.com
They look like this:
Much longer than stock:
But, the bolt holes do not line up with frame holes on a CJ:
'Redneck Ray" fabrication time. Piece of aluminum:
Hack saw and a drill press (never mind the one set of holes that is slightly off center, that is before I got the drill press involved LOL):
"Redneck Ray" math showing how I came up with this length bump stop being correct front and back:
Basically:
Front shocks have 4" compression at rest before they bottom out, but OEM bump stop to axle distance is 6".
Rear shocks have 5" compression at rest before they bottom out, but OEM bump stop to axle distance is 7".
By adding the bump stops, I am not losing any travel, I am just preventing the shocks from being the defacto bump stops.
I am using the OEM steel bump stop plates, with my adapter plate, to make all of this work:
Basically, bolt the steel plate/aluminum adapter plate to the frame, AFTER you install the downward facing bolts that hold the bump stops to the aluminum plate. Once the plates are bolted to the frame, slide the bump stops on to the downward facing bolts. Done.
I am not concerned about the aluminum plate bending, because the steel plates on either end of the bump stop are bearing on the bolt heads that secure the whole thing to the frame. The bolts that secure the bump stops to the aluminum plate are right next to the frame bolts, so I should not bend the aluminum over a 1.5" distance. If the aluminum does bend, easy enough to make steel plates. The other reason I used aluminum - it was raining all weekend so i could not paint steel plates!!!
Extended Bump Stop Daystar Wrangler YJ 1987-1996 | Daystar
Basically:
