I'm a sick, sick man... two in three days!!!
Craigslist is the devil in computer form.
Found another Grand Waggy listed this morning.
Initially, I just noticed that he had a spare set of headers and asked if he’d sell them separately. He gave me a price on them and happened to mention that
if I was interested he was relisting the Jeep for $500 less.
That made me look at it more closely and I saw that the engine was a rebuild with 5k miles on it…. Hmmmmmmm.
Started researching the price of parts, emailed some questions and got REAL
interested.
With the title to the first Waggy in hand, and the thought that I had about possibly putting a 360 in my Postal... parting out the first one started looking REAL good, with the profit working to basically lower the already low (IMHO) price on Waggy 2.
Here was the listing:
Clean 1988 Grand Wagoneer with approximately 5000 miles on the engine and many upgrades:
Edlebrock High Performance Intake
Edlebrock Carburator
Edlebrock Tubular Exhaust plus additional set still in box - titanium coating
Edlebrock Shocks
Power Master High Torque Starter
MSD Ignition System
2" Lift
New Khumo Tires
New Brakes - front and rear
New Carpeting
New Seats
New Windshield
New Door Seals
New Driver's Side Window Seals - have passenger side just not installed
New Side Marker & Signal Lights
Not so good stuff:
Left read qtr panel needs replacing (minor rusting) - will provide the replacement panel
AC doesn't work - don't know why
No radio
I read this as the Jeep had all those “new” pieces on it already (which always makes me skeptical without receipts) but in fact, many of them were sitting in boxes AND he had receipts for all of it.
He also didn’t mention that it has the towing package.
The starter was an error, he said he ordered one but cancelled the order and forgot that he didn’t have it in the closet with the rest.
BUT, I’ll forgive him for that one because…
Things new in original boxes/packaging:
Rear drums
Wheel cylinders
Rear rubber brake line
Brake shoes
Non-driver door light switches
Door lock/keys
Gaskets for almost every exterior part that screws on
Chrome trim pieces galore
Door window gaskets
Passenger vent window gasket
Front wheel bearings & seals
Left rear lower quarterpanel sheetmetal
Edlebrock titanium coated headers
Door chime
Tie rod and tie rod end
Ball joints
Poly body mounts
Ventshades
Large resistor (ballast?) with bracket
Charcoal canister filter
Recarpeted tailgate carpet panel
Leftover pieces of carpet
Used parts that came separately:
Good spare tire with rim
Catalytic converter
Wire wheeled hitch, needs paint and installation
Fuel pump
Headrests
Chilton’s
Parts put on in the last 5000 miles (some in the last couple months, need to look through the receipts more):
Exhaust
Alternator
Fuel pump
ALL hoses (heater, radiator, vacuum)
Belts
BJs 2” springs
Edlebrock shocks
Rancho stabilizer
Entire front brake setup (calipers, rotors, pads, hoses)
Edlebrock intake, carb, headers (non-coated)
MSD, Accel coil
Kuhomo tires
All marker lights, turn signals and headlights and trim pieces/frames
Battery cables
The interior was completely redone with the exception of the header and dash. The “new seats” were removed and refoamed/reupholstered VERY well. The carpet has a couple strange spots and I think it’s keeping the gas pedal from reaching the floor
but it’s very nice. The door skins are in great shape. I will need to figure out the radio and he removed the antenna, but the speakers are all Bazooka replacements.
Rough spots
The few bad spots are the roofrack mounts where the seller said the PO put superglue under the gaskets to keep them from leaking. The glue ran down to the raingutter and ate the paint and now there’s rust in most of those spots. A couple of small spots in the gutters were also rusting.
The left rear quarterpanel is rusted through, but not nearly as bad as many I’ve seen and it’s almost out of sight.
It was apparently gold originally and someone did a half-assed paint job with the yellow, but it basically appears to be in decent shape and not cracking or peeling. The jambs, underside of the hood and all are still gold.
The rear seat windows don’t go up/down easily and the rear window has a lot of trouble going down, but up works pretty well (go figure)
The wipers (raining during test drive) don’t have the intermittent setting.
The cruise doesn’t work.
The AC doesn’t work.
The driver’s door dome light switch doesn’t work.
The positive battery cable was loose and a little corroded, which made it not want to start after a stop for gas on the way home. Thought I’d found why it seemed too good to be true, but a little twiddling got it going and I fixed it right back at home.
The thorough inspection (after getting home
I didn’t give it a properly thorough once-over when I was at the sellers house. I was in decent work clothes and it was dark and raining on us. I did see enough of the frame to know that it was great and could see the axles/brakes/u-joints were solid, so I assumed it was as nice as I thought it could be.
Once I got home and changed, out came the droplight and creeper (and camera). I went all over it and it was indeed as good as I’d hoped. The rear crossmember has a good bit of surface rust and there’s some rust around the gas tank, but it’s far from “rot” and looks easily fixed.
The underside of the floor is amazing with almost no rust at all. There appears to be a slow leak of ATF at the tranny/Tcase joint, but nothing major. The body mounts aren’t real bad, not sure about the poly set for a road-driven rig…
Well, that’s about it…. Oh, photos
http://kateanderic.com/jeeppics/woody2/index.html
We’re psyched about it… I couldn’t believe how stuff just kept coming out of that closet at the seller’s place. I laughed out loud at the whole scene many times. I’m glad my buddy came along so I have someone else that can back up my story.
