Got some things to do first. Did have it up to ~67 and no vibrations. Tried airsoft beads in them for the first time and seems to work well. No balance at the tire shop, just the beads, stems and mounting.
I did 1 lb of "match grade" (LOL!) Airsoft beads in each of my used 39.5" Boggers. They balance out just fine if I'm going faster than 35 mph. Driving with the top/doors off for the first time was a little trippy though because I can hear the beads hit the aluminum rim each time I come to a stop.
So this happened today. Interco IROK ND 37s on their BirdDog rims. Took the opportunity to get some shots of the Postal and LJ together since I haven't had the two tops on at the same time before.
Still 35" and 4.56 gears. Been to busy pushing out the new magazine issue to deal with the signature now that I put the BDS 5" lift on. Still the 4.0/AW4 with no plans to change that until a stroker can happen, that's always been my plan for the Postal. In a nice coincidence relative to the timing of the new lift, I am trying to work with a tire company on some other tires, but nothing firm yet. That would likely require some other changes
I had to play the compromise game when I chose the 4.56 gears. If I hadn't had the automatic, it would have been a no brainer to do 4.88. With the AW4 and knowing that I highway drive this thing regularly, I didn't want to give up reasonable high-speed cruising. I can't take poking along at less than the normal cruising speed on the highway, ESPECIALLY with the length of the trips that I take. I will put in 12 hours of driving a day, at least, on my solo drives.
Off road, they're definitely a touch tall.
In the end, if I were to do it all over again, I think there's enough left in the 4.0 at 75-80 MPH that I could have gone with the 4.88s and still been happy. That would put it in a better place off-road for sure. It's never been a real problem on the trails to the point that I was mad that I only had 4.56 or anything like that, we're just talking about degrees of good.
Perhaps an Atlas IV? Then you CAN have the best of both worlds.
Still 35" and 4.56 gears. Been to busy pushing out the new magazine issue to deal with the signature now that I put the BDS 5" lift on......
The problem with the TJ/LJ is that they have such a deep overdrive relative to everything else so you need to go deeper on a gear selection or your engine is lugged down and trans temperatures go up.
Sent from my SM-G920V
Yea, autos I'd go 5.13 or 5.38 gears with 35's and an auto. The overdrive is a whopping .68 which kills power.
