Vintage Barry
New member
- Severna Park
- MD
I just purchased a CJ8 that has a 304. The exhaust is wasted. I'm not looking for noise. Dual. Any ideas where to look and what to avoid? Thanks for any input, Barry
You’re into the custom exhaust world with this. If you’re not going to DIY, it’s time to find a good exhaust shop. Decide what you want for manifolds/headers and then get to the shop.Thanks for your reply. I have stock manifolds but I'm not opposed to headers. Who sells a good kit for duals or should I go to a muffler shop?
Did you keep the catalytic converter on or did you remove it? BarryMy Scrambler had duals on the 304 when I bought it. After I restored it, I went back to a single 2.5" exhaust. I had a shop do the exhaust as a stock Y pipe would hit the front driveshaft. They ran the pipes back on either side of the trans/t-case then merged them behind the t-case. See picture. I have a Flowmaster Super 44 muffler. I think it sounds a lot better and performs better then dual exhaust.
One of the guys on here told me how he did dual exhaust. He moved the 15 gal tank over to the center so the tail pipes could go on each side of it. I liked that idea so that is what I've done on the two Scramblers with 304s that I'm building now. Grabbed a picture just before backing the chassis under the body. The exhaust goes all the way back and turns 90 degrees and out the sides. One has headers and the other has manifolds. The one with manifolds will probably be more quiet.
It was already gone when I bought the 8 and it had dual exhaust already. I didn't add it back on when I have the single exhaust put on.Did you keep the catalytic converter on or did you remove it? Barry
