I want one of these....imagine the possibilities!
Now that is slick. It's a shame the printer cost so much, the scanner not bad.
Don
We can all chip in.....
That is cool, I could never justify the cost...whatever it is, but it's cool.
That is what I do at work. Well part of the time.
That Next Engine is a crappy quality scanner, but the dimension printer is pretty good. About $35k. There are two carts in the front. So simple that a secretary can be in charge of the printer. When one of the carts gets low on that plastic line it beeps, you snatch the old one out and install a new one and it keeps going.
They are nice as toys but that particular version is hard to use for real parts.
There are other types of printers that can produce Wax, Resin, and Corn Starch parts. So of the stuff that we are working on is doing one off Wind Tunnel models for very intricate and hard to machine things. We can use this cool Titanium sintering machine, or cast them out of Iconel.
Lots of very cool things out there.
One of the things that I was doing was having the ability for the Space Shuttle to have a camera similar to that scanner but better actually take measurements of damage to the tiles on the shuttle while in space. Then transmit that data to earth, I then was converting the raw measurements into a faceted surface and then making a continuous NURBS surface in CAD.
We could then feed that data into one of the printers make a negative and cast a positive out of ceramic, fire it in a kiln, and then place it in a wind tunnel and get results to determine if the damage would propagate and be very bad, as in the other one that caused the crash. Or if they could continue on to earth.
If the damage is bad we now have ways of doing a patch in space, but they have not been fully in flight tested yet. So we are hoping to not have to use them.
BTW, that whole process of seeing and measuring damage to creating a model to getting it into a wind tunnel and getting a Go/No Go decision is down to less than 36 hours now.
Carl
I just wanted to say that what they were showing was OK, but that there is way cooler stuff being done out there.
If you want to see wild prototyping. Check out some of the stuff being done with High Speed Mills. 10,000 RPM spindle speeds. The finish on steel is almot polish from the rough milling.
Carl
When are they going to build one where I can drive my 8 in and it will build one just like it? :D:p :D :p :rolleyes: :rolleyes: :rolleyes:
Carl- what I was saying was that you have a very cool job!
X2!!! Hey Carl...any apprenticeship openings where you work? I've got 12 years of aircraft structural repair experience ;)
You'll be able to build your own 1/24 scale Scrambler soon, Ben! :D
Boy would this equipment make things easier for the resin project! :thumbsup:
I had some exposure to this stuff working for a past client, there is some incredible stuff out there that will blow your mind. I can also attest to the fact that Carl has a very cool job playing with some sweet toys and tools. We actually bumped into one another at a conference for this kinda junk once in Raleigh.
The most interesting thing to me with these printers is that you can print something that's physically impossible to machine. Limited practicality because of the limitations of the materials you can use to print with though, but very very cool. A number of these printer manufacturers were showing off that exact capability throughout the show.
Don
He sort of ignored the coolest part.... you have no actual need for the plastic printed model. Yeah, it's neat, but you can get it right on the computer and feed it directly into a CNC machine without bothering with the plastic. If you want to test fit, just have them machine it out of something cheap and skip the printer altogether.
Like I said, sure you can cast stuff assembled, with moving parts, but what good is it other than being neat if it's made of ABS???
The company that we worked with made the software that processes the points from the 3-D scan and turns that into the model with the actual surface (the little triangles that he showed). The mathematics that go into that are incomprehensible to normal humans like me ;)
One of the very cool things I was talking about was the Sintered Titanium metal printer.
It can spry Ti powder into a stream using a pinpoint crossing of Industrial Lasers you can make a solid point. So inside this machine you can build a very thin, 0.005" thick part. Out of solid Titanium. Also there is very little waste product.
If you have looked at the price of steel or stainless you have an idea of what the Ti market is like. But it is Mega Space bucks, and very hard to machine.
One of the things that Boeing was working on was the ability to form Jet nozzles out of this Ti Powder. Really cool in that you can blend sheet metal thickness and then have ribs that monolithic to the structure. So instead of bolting, riviting, welding, or bonding these ribs are solid with the material at the same temper.
To do that traditionally you would have to start out with one big billet of material and then machine down to it. That is pretty cool.
Carl
There may be a limited ability to use the material that comes from the printer. But one of the things that we do is doing on off castings of parts.
We can take those plastic parts and then bond them into ceramic slip, kind of like thin mud. Then you bake the ceramic and plastic. At a high temp, like 800-1500 degrees the plastic will burn and vaporize, leaving a cavity in the ceramic. Then you can pour liquid metal into that cavity let it cool and then break away the outer ceramic. This will leave you a rough cast metal part of the original. From there you can do final machining just like on a hub or outer C for an axle.
Once you have that faceted model you can also make it into a big square block on the outside with the surface on the inside. You can pour whatever ceramic mixture into the plastic and let it harden. Then when you fire it in the kiln the plastic on the outside will melt away. You would be surprised how many things these days are being made from ceramic. That technology is coming along very quickly.
So you can dream up a head and port design, cast it in plastic, build a ceramic head and fire it then put it on the engine and test it.
Lots of very good uses for industrial ceramics.
Carl
Geez. I am still banging on rocks and grunting at things that fly with my little AutoCAD program. I subscribe to NASA Tech Briefs, but just giggle with a vacant look in my eye at my absolute lack of understanding of anything they are writing about.
That stuff you are describing is just amazing.:bow:
Amen, brother....
