- Crestwood
- KY
That's a good son in law?Thanks for the suggestion! My son-in-law actually works for a local fab shop. He made his own tank for his Early Bronco. I might end up going that way.
Randy- This had me chuckling as it seems like we all have the same time/priority issues. BUT, you are making some serious progress. Strong work!!! Will enjoy following this one.Well, this is a long overdue update. I can’t believe that almost two years have gone by since I last posted in this thread. Three of my projects sold and now Red is sitting in the new shop! So it’s time for a project update. I have changed the powertrain plans a little bit. Seeing as I kept the 6.0 and 4L80E out of the J-20, I’ll be putting them in Red. A bit of overkill? Maybe... I’ll probably keep the 3.54 gearing, should be plenty with the 6.0 torque and 31” tires. Also kept the Vintage Air Compact 2, I’ll be using that too. Once I have something picture-worthy I’ll post it up! Hopefully soon!
He's on a mission now !
I'm really digging that! I might have to steal that for my build.
Currently the plan is to go over the top with a 1”x2” thick wall tube right where the old crossmember was. I think that should be enough.
I doubt that replacing that cross member with a shallow "c" section would make much structural difference in the frame. The factory cross members were only held on by a very poor weld on the tab of the cross member. The rest was only there to keep it from flexing in the center. Basically it was marginally better than a piece of flat stock (except flat stock would be very weak in resisting bending in one axis, good in the other). A tube or c channel would be equally as effective as the stock member.
Do you have any shots showing clearance between the spring hangers for running exhaust? Looks like there might be more clearance for a dual exhaust setup?
Lastly, I have been looking for a small 110 welder to do sheet metal and other light jobs. The big Lincoln is amazing but a bit of a beast on small stuff. I stopped by the local farm store and they had a discontinued Hobart 130 on the shelf. It was missing the tip and ground clamp, so I went into bargain mode. Amazon sells them for over $500, and this one was on the shelf for $449. By the time I was done, I walked out the door with a new welder for $275!!! Score!.
Picked then up a while back. Probably sell them, I don’t have anything they fit anymore.Nice wheels !
