Recap: Original 258 engine had the crankcase breather hooked up to vacuum on the intake and had so much blow by that it was blowing oil into the carb. I directed that to a stand-alone breather mounted to the firewall and trap that also quickly filled with oil and filled the cab with smoke.
On a whim, I noticed that the heater core wasn’t hooked up, after hooking up determined there was a leak.
I did the blazer heather motor swap, and replaced the core.
Having the dash off I realized that the various POs did some terrible things when it came to wiring... fixed a lot of it and added the KC front lights, built the stock style harness and found a stock fog switch for the dash. Replaced headlight switch and all heater vent controls. Did heater box resto also.
At that point a 97 XJ fell in my lap and the swap was on.
- Engine, ECM, PCM, harness from ‘97 XJ
- PCM mount from YJ and grafted to CJ batt tray
- Novak pump, sender, filter, return
- HESCO CPS and harmonic balancer
- Flex-a-lite dual electric fans for a CJ
- MORE motor mounts
- Banks 4.0 header
- Flowmaster and 2.5” custom exhaust
- ACT clutch for a 4.0
- HESCO pilot bushing for 4.0 and CJ
- Novak hyd clutch conversion 7/8 slave and 7/8 Wilwood master
- YJ brake power booster
- custom hyd. lines to adapt XJ power steering to CJ steering box
- Pioneer stereo, Kicker in dash, select increments centra pod with kicker and intra pod with kicker sub
Still need to tweak the fuel and temp gauges to get consistent readings and adapt the XJ a/c to CJ lines. But it’s running and driving!
