New Project
It doesn't look as good in person as it does in the pictures. I've done a bust out on the body work and paint. I should have given it a second coat of paint but I didn't have enough time. I'll give it a second coat later. I'm just hoping to get everything done in time for the Nationals. If I don't I'll be scramblerless because I pulled the motor out of my yellow one to put in this one.
Don
keep it up Bobcat, we want to see that thing in Clayton.
Clayton
Faster Don , Faster!!:D :D LOL
Sam, "Sams Dad" (otherwise known as Kevin), "Sams Mom" (otherwise known as Beth) and I are heading out around 1ish on Wednesday if you would be interested in joining us. We could meet up around Louisville or just west of there. We will be making a slight detour to pick up the Great 8 Crarity Scrambler in Thayer, KS, but we would be thrilled to have you join us. Kevin and Beth are driving Sams 8 and Sam and I will flat tow mine to Thayer and then load it on the trailer with the SOA 8.
Trying
I'm working as hard and fast as I can. Worked on it till 2am the last 2 nights. Right now I'm having problems with engine cps system, and still have to bleed brakes. All the little things are killing me, plus trying to do it by myself is tough.
Don
Looks Like I'm Gona Be A No Show At The Nationals
Right now it doesn't look good. What I thought was going to be a plug and play on the motor has turn into a nightmare. Can't get the engine to fire up. No voltage going to coil, and can't figure out why. Right now I feel like I'm beating my head against the wall. This is a factory YJ fuel injection system, I've been checking the wiring against the wiring diagram and can't find anything. I also have a cd with wiring diagrams but I'm also having troubler with the cd drive on my computer so I can't check these diagrams.
So I guess as of now I'm not going to be able to go to the nationals. Right niw I am really BUMMED, PISSED, AND WHAT EVER ELSE, plus a whole bunch of other stuff I can't say on here.
Don
in the yj harness, there is a plug that goes through the firewall. Make sure you connect your keyed ignition to the YELLOW wire. I had this issue when I installed a '92 into the wife's '88. This fires the computer AND coil! I can send a photo of the plug in the morning....or load it on a trailer and bring it clayton!
Got Er Done
Geting ready to leave for Clayton in a few minutes.:cheers:
It worked great
Well, it worked great down in Clayton this weekend and got it back home in one piece. Now I'll have time to finish up on all the stuff I didn't have time to do before the Nationals, and do a lot of tweaking on other things that need improving.:D :cheers: :cheers:
Alright Don!! I'm glad it worked out after all of your work.
Avatar
Did you notice my new avatar pic? It is from Clayton.
In action!!!
It was a pleasure to wheel with you. It is amazing that you finished your jeep and loaded it up on a trailer and hauled a$$ to clayton, and then wheeled the daylights out of it!
Thanks
Thanks for the pics. It's hard to take pics of yourself in action.
Don
