It can be done either way. Less masking if done off. I did get a small scratch when I put the roll bar in (did it by myself) if you have help the scratch won't happen.
WOW!!! Crank on it. I want to see that at the nats. I myself am in tear down mode. Pulled the axles on mine and redoing all the 4 link mounts. Can't wait to meet you.
I'm in the process of installing the roll cage. Hopefully some pics tonight. Going to try and get the trans and transfer installed today also, with engine swapped tomorrow (fingers crossed).
Finally got engine, trans and transfer installed. The big stuff is no problem, it's all the little things that are time killers. Still have to bleed brakes, install front drive shaft, finish hooking up gauges, install bumpers, winch.
You're my new idol. That's amazing work in the amount of time you've been at it and it looks incredible! Seeing builds like these makes me want to do a frame off in the worst way
bumpers and front driveshafts can be done in the parking lot before the first trail ride
