New purchase...'85 Scrambler Renegade
Now with the AJ's full hardtop I got from Thoma (twmattox). I'll be heading to Finish Masters with the original 1/2 hardtop to get the tan paint scanned, and get paint mixed to repaint the full hardtop tan. My buddy Mike will be helping out by spraying it for me (thanks Mike!). :)
Craig
forum
There's a lot of cleaning and painting to do there, Craig...to get it to your standards :rolleyes: .
Boy, I'll never get away from that stigma with the guys who have been around this board for a long time, eh? :) The cosmetic restoration will wait a year or two, as my primary goal is to get the diesel installed this Winter, and get the Scrambler running on biodiesel or WVO (I'm still not sure which route I'm going yet). I want to enjoy it some before I tear the whole thing down for a frame-off "resto-mod".
Craig
EDIT: The 1-2 year wait for a cosmetic restoration will give me plenty of time to clean, paint & polish my Dana 300. :rotfl: I'll try to make it even purtier than my last one.
forum
Drat, you beat me to it, I was all set to go find that pic of the D300 :rotfl:
No need to clean it
You shouldn't clean that engine bay. Finding that Red Georgia Clay in Michigan is rare indeed...
Craig
Haha! You'd never know it now...........that D300 has had the paint smoked off it and a baked on NWLP Michigan mud powder coat applied ever since that 401 was slipped in front of it!
Just Kidding.....I've been taking good care of her..........just a little Keweenaw dust and an ocassional splash of mother nature on her. Sometimes it sucks having such a clean Jeep (I just can't bear to take it out in the woods much!), but she sure gets the looks!
(Sorry I haven't kept in touch much.........dial up sucks!)
Thanks for posting, Scott. I'll have to check in with you shortly to catch up. :)
A few updates on my project...
A buddy of mine just hooked me up a 250-gallon “tote” like the one below for $25. It’s a 1-time use item for food-grade liquid. This will be the basis for my WVO collection trailer; I’m going to build a heavy-duty 4’ x 8’ trailer with a pump system to collect used veggie oil from restaurants. I know a guy who built one of these trailers, and he can fill his 275-gal. tote in about 5 minutes. I have a rear axle & springs from a J-10, so I'll just have to build the framework for the trailer out of box-section tubing.
I also collected a couple more parts for the Scrambler this weekend. I picked up this wide-track Dana 44 from PavementPounder this weekend (thanks), along with a new Omix-Ada fender that I traded some Laredo seats for (the original driver front fender is dinged up). Koz had just replaced the bearings and rebuilt the Trac-Lok in the D44, and regeared it to 3.54. I also mounted up a nice set of BF Goodrich AT P235-75/R-15s that I got from my buddy pokerob. According to David Langs SD-33 performance calculator, the performance of the SD-33 diesel will be almost identical with this setup as it was with my old CJ-10a with 34" tires & 34s.
To help spread out the financial layout for the Scrambler, I plan to stick with the stock-height springs & 235 tires, and run a 2WD setup for a year or so. It'll be used mainly for road use anyway. Once I get the money to regear, and to buy a 4" lift (required to clear the front driveshaft with the TF-727 trans) w/33" tires, I'll do so. However, the cosmetic restoration, including galvanizing the frame & having bodywork/paint done has a higher priority.
Craig
Wide-track D44 rear axle that'll be swapped in by Spring.
forum
A 250-gal. liquid tote (very similar to this) will be used for WVO pick-up.
Craig, I don't know what transfer case or front you're planning, but if you're running a driver's side drop t/c and front, you don't need the lift to clear the front driveshaft even with a 727.
You probably know this already, though....
Thanks for the suggestion, John. I thought briefly about that, but I'm just going to run the stock Dana 30 and Dana 300 t-case. I don't want to get into a high-dollar front axle/narrowing swap, and the Dana 30 will be plenty strong for my purposes. I also sold off all of my driver-drop t-cases. Eventually, I plan on getting a RE 4.5" or BDS 4" lift, but I'm in no super rush. My primary goal is just to get it driveable on biodiesel. :)
Craig
It was a productive Thanksgiving morning. I got up at 6:00am, pulled the SD-33/TF-727/D300 from the '10a frame, and got the first "trial fit" install in the Scrambler. I still need to move it back just about 1 1/2", but need to remove the TF-727 shift linkage bracket from the bellhousing first (it's hanging up on the proportioning valve/frame-mounted 999 shift linkage bracket).
Craig
forum
Craig, there is no better way to start the day than what you are doing. Good luck on the build.
The '10a frame is about 4 1/2" wider inside-to-inside than the Scrambler frame (remember, it's based on a full-size Jeep frame). However, the '10a frame uses a standard CJ hood, grill (even though it's missing headlights), radiator, etc., and the firewall is in the same position relative to the grill. So, in order to get the same fore/aft positioning for the SD-33 motor, I built a motor mount jig using some misc. steel & some old 258 motor (block) mounts. I'll be able to move the jig over to the Scrambler frame, bolt it into the grill mount, and know where the motor mounts need to be positioned, and at what angle they need to be. I can then start fabricating the motor (frame) mounts for the Scrambler frame.
Craig
forum
Project Update (12/14):
I had this week off work, and did a lot of micro-adjusting with the motor/trans/t-case positioning. Regardless of what I did, there was very little clearance (3/8-5/8") between the front differential yoke and the oilpan. It got frustrating enough that I considered switching to a driver-drop front axle setup, which would also be a lot of work. After hashing through several less-than-ideal options, I was looking at my oilpan (with ~3/8" clearance), and realized the the driver side is "wedged" (cut out) to accomodate a driver-side differential. Since International Scouts (which also used the SD-33 diesel motor from '76-'80) are passenger-drop, I called Nissan Forklift to see if there are more than one oilpan options; sadly, they only had one part #. However, after talking with my friend Don (who used to work on '10as when he was in the Air Force), he said that International may have just added their own oilpan.
That's when I hopped on Northwest 4x4's site, as I know that the guys there (Clark/owner in particular) are big SD-33 nuts. Sure enough, I found this photo from his 1980 Scout Traveler restoration.
Eureka! The oilpan is carved out on the passenger side! I talked with Clark about this, and he told me he'd get me some better photos of the Scout oilpan...great guy, BTW!
Come to find out, the military swapped their own oilpan on the SD-33. I bit the bullet and ordered a Scout SD-33 oilpan from Jesco today. Jesco is actually the company that supplied the SD-33s to the military for the CJ-10a builds back in the mid-'80s. They were very knowledgeable and helpful. The Scout oilpan will take care of my yoke/driveshaft clearance issue with the oilpan. Next on the drawing board is addressing the front driveshaft clearance issue with the TF-727 auto transmission. I'm currently investigating 2-pc. driveshaft options, but I'm open to other suggestions. I'd prefer not to lift the Scrambler 4", but will if I have to.
Craig
Updates...
My buddy Mat (matnic) designed and printed me some sweet adhesive WVO container labels. They look very nice. Thanks again, Mat! :) I have now collected 60 gallons of WVO (all free), with 15 gallons coming about every 10-14 days. I only have about 16 more of these 15-gallon poly containers, two 55 gallon poly barrels, and a 250-gal. poly tote, so I'm getting concerned with having enough storage space for the WVO until spring. :rotfl:
Onto the project itself. I'm still dealing (slowly) with my oilpan install issue. As I mentioned before, I bought a "new" IH Scout oilpan from Jesco, the company in California that supplied the military with the Nissan SD-33 motors for the CJ-10as. They're friendly enough, but my experience has been less than impressive. Here's how things have been going:
  • I talk with the knowledgeable staff at Jesco regaring my swap from a CJ-10a oilpan (which the military installed) to a Scout oilpan, which is carved out on the passenger side to clear the front differential. They assure me that it's a bolt-on affair, and that the oil pump & pick-up tube are the same for both applications.
  • I receive my dusty, scratched-up $230 "new" oilpan that had some surface rust where it was scratched, and also some on the inside of the pan. Wifey & I both are disappointed that this was sold as a "new" item given the obvious shop wear. Jesco tells me that these have been in the warehouse since around 1980, and that you can get new-new oil pans, but they're much more expensive. I can clean it up, but didn't think I'd have to do this with a NEW oilpan.
  • I also notice that the Scout oilpan is ~2" shallower than the '10a oilpan. Of course, the pick-up tube that was supposed to be the same is too long. I call Jesco back, and they tell me they'll ship me a used pick-up tube for $30. It should bolt up just fine. I also order a $38 oil pan gasket from them, and pay another $18 in shipping costs.
  • I receive the used pick-up tube, which I find is scored pretty deeply (~.004")on one side (see pic). I understand that it's used, but 1) they initially told me that I wouldn't need one, as the parts were the same between the '10a to the Scout, and 2) they mentioned nothing about this deep scoring when I was on the phone with them (the 2nd or 3rd time). If they would have said, "Hey, we have a used part, but you'll have to have it surfaced prior to use", it would have been fine. But they didn't.
At this point, I started thinking that I should have just clearanced my existing oilpan by cutting/rewelding it. However, a side benefit from this sequence of events is that I met a very nice neighbor about 2 miles from me who owns a mold/machine business, and also farms directly across the street from me (very down-to-Earth guy). He's surfacing the pick-up tube for me, and said it would be no more than $20. I should have it back within a day or two, at which point I can move forward.
I highly doubt I'll be ordering anything from Jesco again. I thought their in-depth knowledge of these motors was worth my business, but I'll stick with dealing with my local Nissan Forklift business (in Grand Rapids, MI) for parts going forward.
The good news? This build is occurring at my leisure, and I'm on no fixed timeframe for completing it. Therefore, these delays aren't really setting me back any. :D
Craig
Tranny pan issue
Have you thought about getting a deep/extra capacity tranny oil pan and cutting/re-welding for the clearance issue? The deep pans are only about $60 from Summit Racing.
Bo
No Fixed Time Frame
Craig,
What do you mean NO FIXED TIME FRAME, you have to have it done by June for the nationals. That way we can both debute our new scramblers.
Don:cool:
At a leisurely pace, you might be a Superfund site before you're done, with all of the oil. :eek:
