Newby and some questions
chavezychavez
Chickasha
ok
Hello,
I am in the market for a scrambler and know nothing about them right now looking at a relatively rust free 1983 hardtop 6 cylinder 4 speed for about $6,500.
My question is how much would it cost to add A/C to one? I am in the Navy but stationed in Oklahoma and it gets hotter than Hades in the summer time.
I am looking at being a daily driver with a commute of about 80 miles a day round trip and as a hunting rig how do they do gas mileage wise?
Is the 6 cylinder fairly reliable?
The rig has about 170k on it does not use oil or leak anything.
Looking fwd to your replies.
thanks matt
welcome aboard..!! I think if its not leaking oil...it probably dont have any in it!!!
Mileage can vary a lot, 16 mpg is sort of average, but anywhere from 11 mpg to 21 mpg is possible.
A/C kits are out there. They cost about $800 to $1000 new, IIRC. Then cost of installation, if you can't do it yourself.
Personally, I think if you are looking for an air conditioned vehicle to drive 80 miles to work each day, you're looking at the wrong vehicle -a convertible SUV. A Jeep wasn't meant for AC, but rather driving with the top down and enjoying the fresh air. :D
Amen!
Welcome
Welcome to the board.
The $6500 price tag for a rust free Scrambler seems to be a good buy.
I've installed several AC units, both factory and aftermarket in Scramblers and everyone so far has been pleased with the results. It may be a little warmer there, but the 90% humidity here in the Ohio River Valley gets pretty sticky. I have been known to "cruise" with the top off and the AC on full blast for the best of both worlds.
I agree with the 11 to 21 MPG. a lot depends on the drive, gearing and tire size.
Unfortunately, I agree with Scott, if it's not leaking vital fluids from somewhere, it must not have any in it. "It's a Jeep Thing" that must have been engineered into them to leak. :shrug:
:wave:
the reason that AMC never made computers is that they could not figure out how to make them leak oil
Don't let these guys scare you away, with the leaking oil jokes. Once the goofy factory valve cover has been replaced, these Jeeps typically don't leak oil. At the least, my four don't and haven't ever had any leaking issues (other than the one-sided stock valve cover). :)
As was said earlier: hahahahahaha, i cant stop laughing
Yep, the stories of Jeeps leaking oil are all lies and the jokes are all completely baseless. It's only the valve cover, huh? Man, what have the rest of us been doing wrong??? Congrats on your four leakless rigs. Are you changing front and rear main seals each time you do the oil? :bow: The CJ police are going to come haul you away... better watch out! :D
Anyway, back to the original question. I'll say the same thing to anyone looking to make a DD out of one of these (especially an 80 mile trip per day): have a backup vehicle and be prepared to throw $$$ at the Scrambler now and down the road.
Can it be done, yes. Has it been done, yes. Can any 25+ year old, 100k+ mile Scrambler be used as a DD, probably, with enough $$$.
For your safety and everyone else's on the road, there's a lot of things that will need to be addressed right up front and there's sure to be (hopefully) little things cropping up down the line.
The 258 is a great, long running engine and once you have it going good, it will likely keep on trucking for years. But it's really not the big concern in my mind. It's all of the rest of the lines, hoses, brakes, bearings, seals, fluids, ball joints, tie rod ends, u-joints, etc. etc. that can cause you to end up DD-less (or worse if you're tooling down the highway when something goes) if you don't fix them now or can drain your wallet real quick if you try to go through everything to make it a real solid DD up front.
Not trying to talk you out of it, just trying to put it into realistic terms. It sounds like you've found a pretty fine deal on the one you're looking at if you are looking for a good starting point. Pics would help of course ;) :smokin:
No oil leaks? Right.... I just found out the new Chev 350 I installed in my Waggy has started to leak from the balancer seal. Goes to show...Jeeps WILL leak oil.
I just bought a 1985 Jeep Scrambler. It leaks oil from the valve cover too. What kind of valve cover were you talking about that will replace the stock one, or how did you keep yours from leaking?
I don't remember the exact procedure, as mine was fixed about 20 years ago. However, if you have the stock cover, you'll notice that it is only bolted/anchored on one side. Thus, the replacement cover contains bolts on both sides of the valve cover to better secure it to the top of the motor. This requires drilling/tapping the top of the motor. I had the work done by a professional shop, so I can't describe the exact procedure with any hands-on knowledge. BTW, there are metal and plastic replacement valve covers that are designed to bolt from both sides. Mine is of the plastic type, but I see many others that have used the metal cover.
DO NOT STOP THE OIL LEAKS:huh::huh:
If you do, the Jeep will rust out:crazy::crazy:
Now I'm curious, I've never seen one like that, it was either held on by studs on the rockers or all the way around the outside edge on both sides. Regardless, they still sucked and leaked like mad, but never seen one only held down on one side. What was the deal on the other side??
I swapped in a aluminum one I got used off this forum and made up studs to put in the stock bolt holes so it was easier to install/remove, then secured it with nuts. Never leaked again on me using good RTV on a cork gasket.
Guys,
I appreciate all the poking and fun I am going to pass on the one it was going to be a nightmare due to out of state and going on sellers description. I am going to keep looking for one closer to Oklahoma where I can inspect and drive before buying will keep you informed when I buy one.
Thanks Matt
...it was either held on by studs on the rockers or all the way around the outside edge on both sides. Regardless, they still sucked and leaked like mad, but never seen one only held down on one side. What was the deal on the other side??
Well, it has been 20-sum years, so my memory could certainly be vague.:confused: I seem to remember that the original plastic valve cover was bolted on the driver's side and had two secure points in the center. The passenger side was without the perimeter bolts, or even holes to secure the cover to the head. Some mechanic at the Jeep dealership in 1989 might have suggested something on the order of it being "press fitted" at the factory, and the reason for only securing the perimeter on one side -and thus required drilling and tapping the passenger side and a replacement plastic cover with the anchor holes all the way around.
I was only 18 years old at the time, so I could have imagined the whole thing. I remember the original plastic valve cover being blue in color, and it was smooth around the passenger side, whereas the driver side had the slotted indentations for the anchor bolts to guide into the holes. My oil leaks were occuring along the passenger side of the valve cover gasket on the '81 CJ8. I was the second owner in 1988 with 60K on the OD, so I suppose that the cover could have been previously replaced. However, this wouldn't explain the Jeep mechanic's description of the common problem, unless he simply mispoke. After replacement with a black plastic cover bolted all around the perimeter, I haven't ever had a reason to further inspect the replacement part. I'm currently at about 243K miles, and that includes a melted OD cable where the OD didn't spin for about a decade, so I'd guess the actual miles to be at about 300K.
Just for fun, I thought I'd include a picture of my "old faithful" Jeep. This was from a solo camp outing at an elevation of about 10K feet. Scramblers are perfect for an army-sized cot, once the front legs are set in the cab-side of the bed. Tie a rope from the roll bar and back to a tree, it'll make a nice and simple tent with the appropriately sized tarp. Wooden side boards work well for tucking the tarp sides and sealing out adverse weather.
Speaking of valve covers............
I went to the dealer and bought a new plastic one for my 83 Scrambler about two months ago. I bought a plastic one because I am trying to keep this Jeep stock. Anyway, for 1983 alone, there are 3 different plastic valve covers available. My 83 has one hole at the front and back, I think 4 holes on the passenger side, and 3 holes on the driver side. Driver side is held down by special nuts that thread on to extra long head bolt stud things. Mine doesnt have the two bolts in the center. I used a weird rubbery gasket thing from Crown between the head and the valve cover. Mine still leaks. I might remove the gasket and try just Siliconing the valve cover down, like it says to do. The gasket came with a valve cover I bought from Crown, which doesnt work with my factory set up:(
Thanks for that information, Spank. Do you know how the other two plastic covers were different from the one you purchased?
