On board air vs portable air.
sdsupilot
OKC
#21
It’s funny how many different options there are to do the same thing. I didn’t think about welding gas suppliers/tanks. Besides the regulator it would probably be pretty cost effective.
The Warn power plants are really cool, but I already have an 8274.
I am leaning towards using one of the two York’s I have laying around.
Here are my York’s. Both currently have V belt pulleys.
Both of my compressors have the same sharp pulley end. If the internet can be believed, that means both are the 210.
I do have the 2 AMC York mounts if anyone on here wants OBA with their AMC engine.
FLCJ8
Palm Bay
#22
Scuba tanks are very heavy compared to a powertank aren't they? I have an old scuba tank and the thing is stupid heavy. How about a beer meister tank?
I'll throw out another possible(?) option.
SCBA air cylinders.
Our old air cylinders were 2216 psi aluminum tanks. We used them for air tools and air bags for rescue/extrication operations.
These were later replaced with 4500psi composite bottles. They are significantly lighter with greater capacity.
Even though our Rescue unit has a PTO driven compressor, it and other apparatus have a regulator setup for the cylinders as backup.
We had an adapter for the fill station to fill SCUBA tanks as well, so not sure if adapters would be readily available at dive shops to fill SCBA tanks.
I've occasionally seen used cylinders available at city auctions when FD's update or change manufacturers.
Worse case would be hydrostatic testing, but it needs to be eventually anyway.
Spieg
Aurora
#23
I carry a CO2 tank and also have a small compressor out of a Cadillac (air suspension pump) in case the tank should run empty.
John N
Rockville
#24
I have a small ARB compressor that runs my lockers. I’ve aired up my tires with it, but it takes forever. I just got a Powertank, I haven’t even taken it out of the box...it should be what I need for airing up. I also have Milwaukee battery impacts, so I’ve got that aspect covered. I don’t know if this is the best approach, but I think that it covers my needs.
rubclt
Charlotte
#25
I have both the power tank and ARB dual compressor. If I could only have one, compressor... because powertank needs refilling and once you used most of the tank you can run out after filling three tires. I have found over the years harder to find places to refill and tanks are date stamp requires periodic inspection. On plus side powertank is fast, easy to install and Moblie, carry to where you need it... for me, I have both, so I can pick the best tool for the job
AK-RWC
south central
AK
#26
I am pretty happy with my York on my AMC V8. Mounts easier to come by for it. I don't know what motor you have. Why does compressor need rebuilt? If they worked somewhat before make sure has oil and run it. Manifold, viar pressure switch, pop-off, coalescing filter, suction filter, air tank, on/off switch and some push-on hose/fittings and your there. To some extent you will need a % of those same items for 12V system. Connecting to fittings off the York may be harder part. I used the old AC hoses from a Wagoneer on mine.
I do not have experience with 12V, but can't imagine they will last as long as a York. Plus York can be found in junk yards or old trucks for cheap, and will fill a tire or run impact faster than 12V. CO2 would be faster.
I would love to know EVERYTHING about your set-up. I've been hauling around a York on my AMC V8s for almost 20 years, and haven't actually learned how to make it work yet. My biggest challenge is that I thought I'd need to make a bracket to rotate the compressor 90 degrees so the oil stays inside rather than getting pumped out, so that's always stopped me from taking the plunge to actually plumb the whole thing up.
Jeeper_4_Life
Scrambler Rookie
Kingman
Ks
#27
I can take pictures and post something sometime, may be a week or two. If it is the AMC mount then you can rotate it standing up with the same mount. I can't remember as I had the mount and everything off when I installed it. You may have to pull the mount off then take the compressor off the mount, turn it so fittings are upright and bolt it back down with the other 4 bolt mounting position, then put mount back on motor.
Scott_P
Benzonia
I have been running mine in the stock orientation and as AK-RWC mentioned, it does push a little oil...I just check it occasionally, but I am excited to learn that maybe I can rotate it up an retain the stock brackets! I have a spare york and brackets and will look into it.
Thanks for the insight! Never even crossed my mind before to see if it would work.
sdsupilot
OKC
#29
Is your suction port on the bottom or top as it is laying down? I've read that you can just rotate the head 180 degrees and bolt it back together. Having suction on top is supposed to reduce oil consumption.
Jeeper_4_Life
Scrambler Rookie
Kingman
Ks
#30
Here is how my York is rigged up.
From compressor discharge it goes into coalescing filter, then manifold block. I thought I had a check valve before the filter, but it doesn't appear to have one unless it is in the fitting the hose goes over? I can't fully remember. I made a bracket to mount the oil separator between fan shroud and radiator using the radiator bolt, and the light ground in the grill. It appears my radiator bolt is MIA, I need to fix that. I have a line from the manifold to the front of Jeep and then one to the tank that is under the rear of Jeep behind the gas tank. From the tank I run a line out the back of Jeep and also another to my 90psi regulator and Air Locker solenoid.
Electrical
150 psi Pressure switch runs to relay, and switch inside the cab goes to relay in picture.
I have a pressure gauge in the cab that I ran from one of the ports off the manifold with nylon hose, but it burst due to heat and I haven't fixed it. I just plugged the ports.
I have a pop-off valve in the manifold and also one at the tank. I wanted to put a drain valve at the tank, but hit hung down below frame so I use a plug and drain it occasionally.
B87D9FA3-1339-4C17-B93B-351186FF7C55_1_105_c.jpeg 782C0FB7-D3F5-4C94-BB75-275F4CBF290D_1_105_c.jpeg 8B8DE54F-268B-48D6-AC20-A745550274D2_1_105_c.jpeg 03875FC2-7258-467E-9762-E948A299FD5C_1_105_c.jpeg 07DB267C-F26E-4A35-9632-3050FA1282C5_1_105_c.jpeg CDD960BB-F176-4567-94C9-BA0E95D4637F_1_105_c.jpeg 7D626A20-749C-41E7-8896-8DF981C977FF_1_105_c.jpeg 7BAACBD1-CD1E-4C44-A93D-293C7DCDEB7C_1_105_c.jpeg DCB61294-8218-453E-8BA8-67645799AC19_1_105_c.jpeg 6472C45D-1142-455A-8047-03F064145D9D_1_105_c.jpeg
