Project "AZZ DRAGGER"
Mounted. :)
attachment.php
Well... Had a bad afternoon after i posted the mounted up pic. My neighbour came over and chatted a bit... Then i noticed 2 puddles of nice clean gear oil under the front axles. BOTH axle seals are leaking... BOTH BRAND NEW $50 AXLE SEALS. Not impressed. When i was installing them i botched 3 of them. So i used 5 of them to get 2 installed properly. (well i guess they were not installed properly).
Anyways i ordered 2 new seals. I found a different style that will hopefully work. Its a pain in the a$$. Already pulled the front axle out of the Jeep and put it on jack stands.
Engine swap is on hold for now... :(
Yep, I hate installing front axle inner oil seals:banghead:
Got a car load of parts for the engine swap. :D should have most of the parts by the time I get laid off in May... Then its SWAP TIME!!! (hopefully)
in the mean time, i'm plumbing the emergency brakes now. :D
attachment.php
Looks great...
How you drove that frame down to me with that trailer is still beyond me...
Trailer works good!
I at a nuke power plant. I only work when the units are shut down for maintenance, which usually means I am off most of the summer and a couple months in the winter. :D
Trailer works good!
I'm at a nuke power plant. I only work when the units are shut down for maintenance, which usually means I am off most of the summer and a couple months in the winter. :D
Damit! I only work when I'm not sleeping! I want off most of the summer....and a couple winter months!
This Scrambler looks amazing! :woot:
I just reread my post.... "I at a nuke plant" lol
I use the term "work" VERY loosely!..
and thanks! :D cant wait to start the V8 swap! :D
What WHAAAT??? :)
Teaser shot... Oh and... The Scrambler is going to have a Porsche part on her now!
attachment.php
Sent from my Illudium Q-36 Explosive Space Modulator
Well, I was planning to just pull the transmission today (sold it), then finish the emergency brake...
I did pull the tranny...
but then got a little carried away...
This weekend, I WILL finish the emergency brake... Then I will have to organize the garage a bit. Hopefully find a place to put the engine until it sells. Next big step? Install the 4500 to 300 adapter that I got from Advance Adapters.
oh and... :bacon:
Back to the emergency brake... Mocked up and working. Now to finish and strengthen it. :)
oh... and... the handle is out of a Porsche! should add at least 500HP!!! :bacon:
attachment.php
attachment.php
Heres the almost finished product... Still have to make a sheild for the brake line and figure out where to run the brake line too.
Installed. (minus lines) Its tight! I'm sure when i get stopped, they'll check for e-brake cables and wont believe me that i have a seperate system. :). I like stealthy.
