Factory GM fuel module install
Today I installed a factory GM fuel module into my Trailquest tank. The tank is fabricated steel, 1/8" thick, and about 24 gallons.
Here's all the parts....
First, I cut a 4" hole in the center of the top of the tank using a hole saw. This step was a pain, and I would recommend using a 3 7/8" saw if I did it again, as the saw always cuts a bigger hole.
Then, I cut out an inner plate and an outer plate, both with an exact 4" hole. I used 3/16" steel. The inner plate had to be cut in half to fit into the tank.
I used a 6.0 Turbo unison ring for my top retaining ring. Drilling 8 5/16" holes in the hardened 1/4" steel wasn't easy, but it made a great looking part.
Using the unison ring as a template, I drilled 8 corresponding holes in the inner and outer plates, and in the tank. I chamfered the holes on the tank side of the inner plate so I could install viton O rings as a seal. I also used copper washers under the heads of the bolts.
I used fuel tank epoxy between the tank and the outer plate. The nuts are metal locking nuts, and in addition to holding the whole shooting match together, they determine the amount the module seal compresses.
Next step was to install the fuel module. It just drops in, followed by the upper retaining ring, and then nylock nuts. The nuts torque down until they stop, this compresses the seal properly.
