/ / Appreciate it everyone \ \
My only plans for it for now are:
1) Get the engine running
2) Do some basic maintenance to it (oil changes, pack bearings, drain gas tank, etc)
3) Put matching ring and pinion in the front
4) Install all the new parts it came with (wheel bearings, front brakes, shocks)
5) Clean up/modify/finish installing the transmission shifter set up
6) Fix the small rust hole in the bed and deal with the windshield frame rust
7) Install a set of factory seats. Got two of the three seats I need, it will be sweet
8) Paint grill to match
9) Try to find some discontinued Warn Internal Mount front lock in hubs for it (same as my red scrambler)
10) Might put some Chrome Moly Dana 44 sized front axle shafts in it, I don't think the stock Dana 30 shafts will hold up to a 350, 33" tires, and a heavy foot
Sounds like a bunch of work, but not really. I want to keep this thing as close to its current appearance as possible.
Once I get it running, the first thing i want to do is go and hit up some sand dunes. The 350 V8, automatic transmission, and all terrain tires should let this thing rip up some sand
