After the ignition parts install, I turned my attention to the carb. Previous "mechanics" have messed with it. It has new gaskets, and is really clean. Upon further inspection................................
This Jeep starts really easy. Turn the key on, 1/2 way press gas pedal down twice, it fires right up, and the centering pins are centered like they should be:
Random picture, showing from top to bottom: Upstream Pulse Air inlet, Downstream Pulse Air inlet, thermal electric switch:
If I remember correctly, at idle, the computer is in "Open Loop", and the metering pins are centered. I could be wrong. Once you give it some gas, the pins will start to move. Hard to see, but they have slid back to the "lean" position:
One problem. After a few minutes, my pins slide all the way forward to the full "rich" position:
Out of curiosity, I disconnected the O2 sensor, no change. I had the O2 sensor I used in my green Scrambler, so I installed it. NOTE - It is getting hard to find new O2 sensors. My local NAPA was the only regular parts store who could get the correct one, and it is coming from Seattle!!!
Broken sensor, short wire, replacement sensor, long wire:
Not sure if this is the original O2 sensor, here are some markings that are on it:
To remove the old sensor, I warmed the Jeep all the way up, and removed it when it was still super hot. In my experience, and not just with Jeeps, O2 sensors are best removed while the manifolds are still super hot.
Anyway, the new sensor seems to have worked, stepper pins move in and out like they should, center up at idle and start up:
But, this did not help the idle.
Getting back to the carb, I decided to mess with the mixture screws. One screw was 6 turn out, the other was 1 turn out. So, I turned the Jeep off, screwed both screws all the way in, then backed them out 2.5 turns. Started Jeep up, disconnected stepper motor, turned them in till the idle dropped some, then back out 50 RPM.
It idles perfectly smooth now at 600 RPM.
BUT, the idle screws feel rough, and they did not seem to be making very precise changes. So, I will pull the carb this weekend, rebuild it and replace parts as needed, plus readjust it.
For now, I am very happy at how it idles, starts up, shuts off, and drives/accelerates/decelerates. A little more fine tuning, and it will be good as new.
Good thing the hood hinges have oil holes!!!
That's it for now
