- Biloxi
- MS
Now for the not so fun part.
A few years back, the jeep would randomly stall out. This only occurred when the outside temperature was over 90 degrees, and I was using the AC. I "thought" it was a fuel vapor lock issue, installed a bunch of insulation on the fuel lines. At the time, the fuel pressure was reading high, at 60psi, so I changed the filter/regulator, never had another issue, thought I "fixed" this issue. Until Friday.
On Friday, the Jeep would kind of "buck"/"stutter"/hard split second "cut off". Just randomly. This got progressively worse as the day wore on. The Scrambler had been doing this in the past, very randomly, out of the blue, maybe 1% of the time. When it was random, I just ignored it. Now, it was regular. No "check engine light" (CEL).
On a whim, I swapped on a new Throttle Position Sensor (TPS). The way the Jeep was acting, it was like you were releasing the throttle, then hitting it again. I changed this sensor, the Jeep drove flawlessly for 3 hours Friday night, with the AC on. It was cooler at night, this might play a part.
On Saturday, outside temp around 105 degrees, idling in traffic, the Scrambler sputtered and stalled out completely. Dead in the water. Would not restart. No CEL. I pushed it off the side of the road, let it cool down, it would not restart. I went ahead and pushed in the schrader valve on the fuel rail, as this had "fixed" this issue before. No air came out, only clean fuel. Key primed the fuel pump three times, no restart. I let it sit 10 minutes, and it restarted, ran like crap. Stumbling, bumbling, could not give it any gas. It cleared up after about 30 seconds, and I was able to drive it home. It did OK on the way home. Again, no CEL.
Time for some research, the Mopar MPI instructions, plus some of my notes:
Some other reference material:
At this point, I am thinking fuel or spark. Checked the fuel pressure key prime and running, right at 54psi. I also was able to check the fuel pressure when it would stall out, right at 54psi every time.
From the Haynes manual:
My fuel set up mimics a 1997 and later 4.0 Cherokee. I use this combination fuel filter/pressure regulator:
From the Hesco/Mopar MPI instructions:
Hesco also mentions this other setup, with a separate regulator, as does the Haynes manual:
Using the Grand Cherokee filter/regulator, and the TanksInc internal fuel pump, I am dead on at 54psi. Not sure why Hesco says 50psi MAX, the filter they supply mimics a Cherokee that can have up to 54psi, like I have:
Long way around, I am 99% sure I do not have a fuel pressure/supply/vapor issue.
Once the Scrambler was home, I could let it cool off for 20 minutes, then restart it. It would start and run perfect for 5 minutes, then just completely die. It would studder real quick, then cut off. If you tried to restart the Jeep, no bueno. It would spit and back fire and if it did restart, it ran like the timing was way out of whack. Again, this whole time, no CEL. I pulled off the TPS with the engine running, as a test, and the CEL came on and gave me a TPS code. So, the CEL works, I am assuming the PCM is not totally dead.
So, all Saturday afternoon, I "data logged" what was going on with this Scrambler. AC off and on. I compared this to my Red Scrambler, which is running perfect. Sorry for the terrible hand writing:
Besides the AIS always being low on my Green Scrambler, nothing really popped out. The low AIS "could" mean I have a vacuum leak at idle, I checked, could not find one. I read on the "internet" that the AIS should read around 32, it reads 16 on my Red Scrambler which runs and idles perfectly. But, pretty sure the idle air control is not the issue.
The numbers on the green one jump around a bit, too, because I was swapping sensors (TPS/MAP/AIS) around to see if it would "fix" the issue. I keep new/spare sensors, so it did not cost anything. Regardless, changing those sensors did not work. Also, when you swap in new sensors, mainly the AIS, it takes the computer a bit to "learn/manipulate" them. So, reinstalled the original sensors, no bueno.
The only thing I noted, with the scan tool plugged in, right before the engine would choke down and die, the timing was jumping up to 24 degrees:
I only have a simple OBD1 scan tool, but I can read 28 operating data fields. This timing jump was the only thing that jumped out at me. Is this a clue, or a symptom??
