About knocked it out last night, but of course one step forward two steps back sometimes....
I noticed Sunday night that the power steering pump looked a little 'cocked" in relation to the water pump/crank pullies:
Laying a rusty straight edge from the PS pulley to the back side of the water pump pulley, you can see the gap at the water pump pulley:
Not much, about an 1/8 of an inch, BUT that is a lot in such a short span. It has probably been like this, I just noticed it. It is probably OK, but it bugs me.
The 4.0 intake manifolds that came with the Mopar MPI had whatever threaded bosses on the front removed. I know they would not have lined up, but it would have gave me something to work to/bolt the rear PS pump bracket to:
On the stock 4.2 intake manifold there are two nice threaded holes that secure this portion of the PS pump bracket/puzzle. I am sure if was really talented I could weld a nut to the intake manifold, but that is pretty risky for my skill level.
So, I "RedneckRay'd" it. I removed the two bolts that secure this rear bracket to the block, loosened up all the other PS pump brackets/bolts. I inserted a washer between the block/PS bracket in the forward hole to shim it out/slightly cock this rear bracket:
Tightened everything back up, voila, looks pretty good to me!!!
I went and looked at my red Scrambler with a 4.0, the PS pump pulley is cocked a hair, not as bad as this one, not worth messing with at this time.
Just need to add fluid/bleed the system, install the steering shaft, and install the M.O.R.E. steering box cross over brace, that's it for now
