Now that I went and bought all new stainless e-brake cables I’m realizing they don’t fit with my exhaust and rear brake conversion. I may end up going with the Lokar e-brake setup. Probably mount it in the center however. Your setup looks great!The other good thing I completed was after I cut down the brake pedal, it still didn't have the space needed (I brake with my left foot, every once in a while I would hit the side of the pedal when braking. Decided to make a hand brake and mount it on the floor between the seat and the door frame. Works great. Only inconvenience would be using a hard door. It doesn't hit the door, just would be a tight reach to set the brake with the hard door closed. I was going to hook a switch up for the parking brake light but if the brake is set correctly, you'll know the brakes on. Now plenty of room for my left foot.
Pulled the washers and nuts off. Pulled the bearings. All were in good shape.View attachment 90646View attachment 90647View attachment 90648View attachment 90649View attachment 90650
The dust shield has enough rot to justify ordering a pair. I got a spindle socket to pull the spindle (much easier than heat, screw driver and hammer). Couldn't find the slide hammer so did the next best thing. Used a hammer and hit the end of the spindle socket at the 1 oclock, 6oclock, 3 oclock then 9 oclock positions. Minor taps in that order popped the seal and worked it out. Looks like I'll have to remember to get a new slide hammer.
Here's some pics. If anyone see's something off with the top please chime in, instructions don't come with pic's of a top mounted on a jeep.
