Truck's shop build
Looking great! It's really coming along.
WildTurkeycj8 said:
how were the OSB cuts along the top of the building? Did you have to trim them more or do anything else?
I made one small trim cut on the last one we did. Everything else looked great.
Truck
Okay, it has been awhile since I posted up on this so I thought I would catch folks up. We finished siding the front to include a large gable vent that looks good. Then we got the steel corner pieces in place.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Truck
Here are some finished shots.
attachment.php
attachment.php
Then I started on back garage door. Had to figure out a way to extend for door brackets, so I sandwiched 1x6 on the "c" channel lip and put a 2x4 on that. Worked well. And got the rear garage door installed.
attachment.php
attachment.php
attachment.php
Then I got tired of trekking through the mud, so I had gravel delivered. Spread it out and made for a much better hike to the shop.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Truck
After much consternation, I ended up getting new garage door panels for the front and selling the 2 used doors I was trying to put together that didn't match properly. The door is up, however the original torquemaster spring was only for a 7' door not a 10' one and couldn't hold the door. So I still have to get with a Wayne Dalton company and get the right spring. It does look much better from the front now though.
attachment.php
My boys & I got the split rail fence back up which cuts across the shop now. I had to rework the rails a little with the chainsaw but but it looks good. Just have a little finish work to do. PS. My dogs are escape artists so I couldn't just leave the gaps.
attachment.php
attachment.php
attachment.php
attachment.php
I needed to start on the electrical and had to mount the meter base (provided by the electric company. It required building out from the building because they will only come straight vertical into meter base and won't do a little "S" turn required since my building sits in on the foundation about 6". So, to do that I need the perforated angle and I had bought several pieces (not cheap) to hang the rear garage door rails (needed almost a 10' drop from the ceiling). I knew the rear hangers were temporary because of the loft that would eventually go in there. So I decided to go ahead and build the loft first in order to use the angle for the meter base. The wall in the middle of the building is a plumbing wall for the bathroom, thus the 6" width. Loft is about 10' tall to clear the 9' tall garage door. The loft area on the righthand side will be about 8' tall which will give more storage height on that side. Currently the loft is 12' x 12'.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Truck
Of course once the loft rafters were up I rehung the garage door track.
attachment.php
attachment.php
attachment.php
This was taken from the back corner of the loft...All that light is coming from the skylight panels. They really let in a lot of light. The above picture shows how much light comes in. Realize I have no other light in the building then those skylights and the front garage and service doors are shut. The rear garage door is only open as much as you see.
attachment.php
Truck
I then build a mount for the meter base and attached to the building. Now I just have to figure out the requirements for service panels. I've been approved 400a service and the meter base is a 320/400 box. I know I can use 2 200A ($125 ea) service panels vs. 1 400A panel ($1200). I just need to figure out how to do it. Once that is done, it is on to mounting lights and running power outlets.
attachment.php
attachment.php
attachment.php
attachment.php
Truck
I don't know if ya'll want me to keep going as I continue on. Let me know.
Truck
Truck
I'm enjoying it! Keep going...
Awsome shop Truck. I've heard the neighbors really love it, too.:p
Keep her coming
Truck,
Keep the posts coming. Love to see the progress. :bow: If you need advice on that 400 amp service give me a call. Been a sparky for 30+ years.
Leaves popped out between yesterday and today. When I drove home from work, I was like "Hey, somebody stole my shop!!!!" If I'd have started this in the summer neighbors probably wouldn't have bitched as much until the leaves fell and then it would have been to late to hassle the county and delay me like they did.
attachment.php
attachment.php
attachment.php
attachment.php
Truck
attachment.php
attachment.php
attachment.php
attachment.php
Truck
Your neighbors bitched?
Had the contractor out today, so I'm getting the ball started rolling here. Have to contact the county tomorrow to get the plot of where my leech fields are. If the spot that I picked out near the house is clear, I won't be doing the quonset style...wife isn't going to go for that and she was already whining about the lilac tree that'll have to go when she saw me over there with a tape measure a month or so ago. Not much grading to do and the electric can be pulled from the house (run a line across the basement, out of the back of the house and across the edge of the backyard)...pie slice of concrete about half the size of the slab for the shop will mate it up to the driveway, so an additional cost savings there too.
Looking at going with a 30x40x16 post frame building sided & roofed in galvy with the translucent panels at the top along the 40' sides and possibly a few roof panels. Service door and 12x14 overhead door on the front so I can load/unload Jeeps on/off the trailer, 8x8 overhead door (I'll get new doors for the house then mix-n-match the decent panels from the old 8x7 doors) at the rear of the side that faces the house...I'll probably loft that like Truck's and use the area underneath as my 'shed' (lawn tractors, dirt bike, etc). Hopefully I'll have the funds to do everything that I want including installing a lift.
