What did you do with your Scrambler today? March 2014 version
I installed the joey bypass. 1 coil per cylinder... definitely boosted the hp and torque ..also adjusted roller rockers.. :)
Sent from my SPH-L900
Never heard of the joey bypass, but I would think the two extra cylinders might have something to do with the increased hp and torque. :rolleyes:
To quote Jim:
SWEET!
Post some pics of the M416 and Scrambler.
Don't have any of the two together yet. Haven't started the Scrambler rebuild yet (other than tires). Plan to take it to my brother's to start end of the month (he had something come up and we had to put it back a couple of weeks). I went ahead and started getting the trailer ready. Plan to have it painted to match the jeep. So far I've stripped the old paint on the outside and painted it. Still working on the bed. Today I pulled it off the frame and took a wire wheel to the frame and hit it with some rustoliem hammered finish, and wired the new LED lights in. Also cleaned up the bottom and painted it. If I get a break in the rain tomorrow, I hope to get the bed back on and the fenders on also. I have a spare CJ-2a tailgate that I plan to have put in while we do the scrambler. My brother's neighbor is a welder and he is going to help us with it.
Here's the scrambler:
Here's the trailer in process:
Lots and lots of electrical/wiring/soldering/heat shrinking.
Finished the T5 install
As you can tell my buddy's an LTX'er
As usual, you find lots more things to get done, fixed the tranny mount, two u joints, and corrected some of my brake line securing (doing this with a lift is day and night). New trans is good and tight. Now it seems the old 258 barely has enough power to pull 5th without the foot to the floor. Next item on my to do list is go back and check my timing.
The Jeep T5 has a steep overdrive, it really knocks out a bunch of RPM, hence you loose some power:twocents:
My stock green Scrambler, with a T5, 3.31, and 30" tires works well, doesn't loose too much "power" in 5th on the highway.
My red Scrambler, that blew up three T5's in less then 16,000 miles, would run well in 5th gear most of the time, MPI/33's/4.10's. But, when I would shift into 5th, I would drop at least 500 RPM. In certain situations, i.e. hills, head winds, etc, that 500 RPM means a lot to a 258 pushing over size tires:twocents:
That's good to hear. I'm right on the 500 rpm drop, I knew the OD would take some grunt. Just need to start scrounging mopar money together!
I drove the red one to work today, more AX15 testing, so far so good:thumbsup:
I working over time so I can spend more money on my additions
Took it to the car wash for the preventative undercarriage wash.....
Sunny out and looks nice.....
Dropped off a pile of scrambler goodies to be sandblasted:
Side steps
Swing out spare tire carrier
Flat top knuckles for a wagoneer d44
Amc 20HD housing, diff cover, shafts, backing plates
351w valve covers, timing chain cover, exhaust manifolds, fly wheel
Smell of burning rubber after a long winter really hits the spot! :bacon:
:wave:
My son and I spent the day on a Buddy's ranch,jeep r1.jpgjeep r2.jpgjeep r3.jpg putting around in the Scrambler. Great times shooting squirrels, and running the metal detectors.
Well used the Scrambler to take bags of leaves over to my MIL's to help fill the hole in her back yard. Then after working on the TJ motor (got it all hooked up but something is missing. Can't get starter to turn over) pulled the hoist out and loaded the axles and transmission into the back of the Scrambler. It heads up to my brother's Friday for disassembly and the start of the restoration.
Washed last summer's beach road muck off (FINALLY!) and went for a topless drive to pick up a new bbq grill. Stalled and lost power steering and power brakes at any stop. Raised the idle a bit and took the old dead bbq to the dump when the realization hit. Each stop involved using brakes and each use of brakes included a hiss. Brake booster blown and sucking away engine vacuum. Time for the first fix of 2014 and a now 30 year old Scrambler!
That is what makes it FUN!!!!
Dain
I wish fun was the word. Everything was coming apart nicely, but the clevis pin is solidly bound to the power booster rod. Next clevis up is bound to the rod from the brake pedal. And at the brake pedal? You guess it, bound up tight! I see a hacksaw blade or a local mechanic in my near future.
On the upside, I found and fixed a leaking fuel hose connection, so I might be fighting to stop, but shouldn't catch fire! :)
Drove the red Scrambler to the beach the other day, you can just make it out in the back ground:thumbsup::wave:
