I installed the joey bypass. 1 coil per cylinder... definitely boosted the hp and torque ..also adjusted roller rockers..
Sent from my SPH-L900
Don't have any of the two together yet. Haven't started the Scrambler rebuild yet (other than tires). Plan to take it to my brother's to start end of the month (he had something come up and we had to put it back a couple of weeks). I went ahead and started getting the trailer ready. Plan to have it painted to match the jeep. So far I've stripped the old paint on the outside and painted it. Still working on the bed. Today I pulled it off the frame and took a wire wheel to the frame and hit it with some rustoliem hammered finish, and wired the new LED lights in. Also cleaned up the bottom and painted it. If I get a break in the rain tomorrow, I hope to get the bed back on and the fenders on also. I have a spare CJ-2a tailgate that I plan to have put in while we do the scrambler. My brother's neighbor is a welder and he is going to help us with it.Post some pics of the M416 and Scrambler.
Finished the T5 install
Now it seems the old 258 barely has enough power to pull 5th without the foot to the floor. Next item on my to do list is go back and check my timing.
The Jeep T5 has a steep overdrive, it really knocks out a bunch of RPM, hence you loose some power
My stock green Scrambler, with a T5, 3.31, and 30" tires works well, doesn't loose too much "power" in 5th on the highway.
My red Scrambler, that blew up three T5's in less then 16,000 miles, would run well in 5th gear most of the time, MPI/33's/4.10's. But, when I would shift into 5th, I would drop at least 500 RPM. In certain situations, i.e. hills, head winds, etc, that 500 RPM means a lot to a 258 pushing over size tires![]()
Washed last summer's beach road muck off (FINALLY!) and went for a topless drive to pick up a new bbq grill. Stalled and lost power steering and power brakes at any stop. Raised the idle a bit and took the old dead bbq to the dump when the realization hit. Each stop involved using brakes and each use of brakes included a hiss. Brake booster blown and sucking away engine vacuum. Time for the first fix of 2014 and a now 30 year old Scrambler!
That is what makes it FUN!!!!I wish fun was the word. Everything was coming apart nicely, but the clevis pin is solidly bound to the power booster rod. Next clevis up is bound to the rod from the brake pedal. And at the brake pedal? You guess it, bound up tight! I see a hacksaw blade or a local mechanic in my near future.
On the upside, I found and fixed a leaking fuel hose connection, so I might be fighting to stop, but shouldn't catch fire!![]()
