Well, finally making progress on the Postal rewire before I can add the stroker and Terminator X… got the under dash harness out to compare to the American Autowire…
This is an “update” harness, NOT a stock replacement. There are a number of things they didn’t include (factory AC, ignition, tach, etc) assuming that this is going on a Jeep with upgrades over stock and adding things (electric fuel pump, multiple accessory circuits, relays for factory fogs and low/high beams, power feed to rear body for a power outlet, switched lights in the rear, third brake light feed, etc)
OEM with two or three distinct branches, depending how you look at it. They didn’t mirror the firewall in these, so the fuse block is lower and more centered right at the end of the heater box, basically.
New with everything running one direction.
I need to spend more time with it before I dig in but this will need to be completely re-loomed and there will be some lengthening needed. Thus far definitely the connector for the rear body harness.
That’s in addition to pulling the various feeds to my Speedhut gauges, pulling out a pile of wiring I don’t need and repurposing things I can use differently than intended. For example there’s the factory fog light switch circuit and American Autowire chose to add a relay for that (and the high and low headlight circuits). So I can pull that switch trigger wiring to one of my switches and repurpose that so it’s fused off the fuse block and eliminate one of my own relay setups.
That will be in addition to pulling out the headlight relay setup I built myself.
I am LOVING the thinking behind this harness, but I have a ton of planning and work before this can go back in.
(Going to start a thread on this part alone as it's going to be worth detailing as it's a fairly new kit.)
