New World Cabs?
I'm really liking the last one! I am curious to see what you come up with as far as the rear door goes. I have been thinking some sort of barn door in conjunction with my acme full length hard top would be nice. It would simplify getting in and out of the rear or the Scrambler. One of my roommates in college has several FJ40's so I could come up with the parts fairly easily. Keep up the good work!
I can show you that - here's the drawing for the barn doors. I had to reduce it a bit for posting here, but hopefully it is still large enough to show the concept.
For the Wrangler, the stock tailgate is used. "Stake pockets" are bolted to the inside of the tailgate.
"Stakes" are bolted to the upper half of the door. These stakes are inserted in the stake pockets, and secured in place with bolts.
The top of the Wrangler tailgate is angled; this angle is used to "wedge" the upper in place against the stakes. A weatherstrip goes along that surface, both to protect the paint and to seal the joint.
An extra factory type tailgate hinge may be used on the upper (pictured), if additional rigidity is needed. Wouldn't know that for sure until a prototype is built.
The stake pocket method of securing the upper to the tailgate will result in a rigid door, but will also allow easy removal of the upper without necessitating the removal of the stock tailgate, so in this regard it is much more convenient than a factory World Cab barn door, but with basically the same external appearance.
attachment.php
For CJ's, the same upper is used, but it is hinged at the top. The same weatherstrip is in place at the bottom of the upper, and it seals the upper to the tailgate when the upper is closed.
Most likely I would use a stock CJ hardtop liftgate latch mechanism to keep the upper closed. These parts are readily available in the aftermarket, and it would certainly have factory look, since it is a factory component.
Does that answer your questions?
Jeff
While I'm at it, I might as well post another drawing I haven't posted yet. Here's the latest incarnation of the Safari cab on an LJ. This is the same "Xterra-inspired" version as on the silver CJ-8. This time with a rear view, and a comparison to a factory LJ hardtop.
attachment.php
And I saw a silver Nissan Xterra on the way home today, so on this one I raised the back part of the roof and put on an Xterra-type rack...
attachment.php
OK, Jeff...how much $$? :D
wow..
I haven't been keeping up with this thread as I should have been..
All great ideas..
my comments..
the rounded rear windows.. they are a really cool feature and awesome retro look, but would be really hard to pull off and expensive to pull off on a production product vs a one off. certainly possible but would just increase cost considerably.
I think you can still get the same look and feel by what you did with those two small strip windows in the back and then possibly the flip open ventilation window in the back sides. I definitely like the look of that..
for reinforcement of those corners and small/narrow spaces that would need some regidity.. there are several other materials that are in "board" format other than can be soaked with resin or encased with fiberglass and resign to give those corners the strength and structure they would need. if you executed it right you might be able to have these pieces of board precut by laser and then set in mold, covered, with glass and then you might be able to not have a "inner" mold.
I just sold two take off full OEM LJ hardtops fairly quickly and for good money. they look like hursts on an LJ because of the very large crest they have in the roof. much more bubble than a factory SWB TJ hardtop. They did this to ensure that the roof did not sag any. Additionally, you will notice they added additional reinforcement ribs in them even in addition to the inner molded piece. We have to do this on the full CJ8 tops we make and it is more of a challenge to keep that crest on the top when you don't have a inner mold for support.
I think a sectional LJ full hardtop that has a unique style that you are suggesting would sell if it was at a reasonable price point. I even think people would be willing to pay more for ability for it to be disassembled.
matt
oh.. and forgot to mention these few opinions too.. have long thought about some way to accomplish a sectional top like this.. and I think it would be an awesome hardtop. My concerns from an overall product though would be ..
a. take an insane amount of R&D and detailed time executing a prototype (which jeff has shown us already with his projects that he is certainly capable of executing with precision detail and quality work)
b. going to be major R&D, production, and real world challenge ensuring all the seams properly seal up against water, wind, and air. there is a LOT of linear feet on it that has to seal up properly EVERY time its assembled.
c. fabricating all of the individual pieces so that they are individually rigid would not be an issue (inner molds and inner reinforcements in the individual parts) I think figuring out how to make the overall top rigid after its assembled on the jeep might be a challenge. Only way to know the answer to that one is to try it.
just my .02
Matt,
Thanks for your detailed replies, it's good to hear from an expert. I'm just an amateur with an overactive imagination and too much time on my hands :). Very good info, thank you.
I know these other "board" type reinforcements exist, I've researched a few of them but I have much more to learn. I'll be doing more research. If you've got any links to pass along to me, I'd appreciate it.
Most of the modularity in my design is to allow for small molds that I could easily make in my home shop, and economy of molds by allowing multiple configurations of top to be made from a small set of component molds. The modularity isn't for disassembly - I'm thinking the tops, once built, would break down into only two major pieces (for the pickup cab, top and back wall) or three major pieces (for the van and wagon cabs, top panel and two side walls), so the only seams to seal would be the seam between the top panel and the side/back panels. That seam is relatively straightforward to seal. All other seams would be permanently joined with either fiberglass or structural adhesive and wouldn't come apart. BTW that's the same number of major parts the World Cabs break down into.
I'm not designing for volume production - I'm designing for very limited production, with custom finishing for each top, because I would never have any plans of going into business with these myself. I just like the idea of designing and building custom stuff, I really enjoy that. Doing it as a business would definitely take all the fun out of it.
But, having said all that, IF I build any of these tops, you and I could certainly talk about you taking my finished prototypes and redesigning them for higher volume production. I'm sure you could take a prototype top I might build and build professional-level volume molds from it.
Since I'm talking "IF", IF I build these, I'd start with the pickup cab, probably in Scrambler size. I'd probably use the Gaucho as the test mule for it. Being the smallest of the Safari tops, it would be the easiest for me to build a master for and solve all of the prototype build issues with. This assumes it will take a while to sell the Gaucho, which means I'll have time to use it for the Safari project. Then, in my perfect fantasy world, I'd do a trade with someone, Gaucho for an LJ, and then I'd build the "Xterra-inspired" Safari cab for the LJ. Hey, I can dream, can't I? :)
But we're getting far ahead of ourselves here, I haven't even finished the Gaucho yet, one project at a time :)
Does that answer your questions? Jeff
Jeff, that clears things up very well! Along with your recommendation to have the tailgate hinge at the top, I had also considered using a YJ tailgate, hinges, and lock mechanism so the door could swing open, much like your world cab rear barn door. Either way, the stake pocket idea of yours would be a must!
I just want to see the expedition camper and matching trailer.... whatever it takes to get to that one. :thumbsup:
This is interesting, I'm not a fan of the Xterra one. I don't like the kick-up in the middle of the roofline because it throws the proportions off for me and the roofrack looks too modern to my eye. I'll still be thrilled to watch if that's the one that gets built though :cheers:
I may be a little partial , I lost my Xterra in the divorce. That said I like the way the roof line goes up since the floor area in the rear is raised about 2 in. if you use a 3rd row seat. The 2nd seat uses the same floor foot position as the fronts. Am I thinking correctly that most who would use this top have the 3rd row seat or am I blinded by my own interputation? :shrug:
... I like the way the roof line goes up since the floor area in the rear is raised about 2 in. if you use a 3rd row seat.
Remember that the extra space you're citing from the kick-up is over a World Cab roofline, not a normal CJ-8 full top. So the baseline you are adding to was already about that much taller than a normal hard top. That's why I don't like it, I know how tall that will make it inside and it just seems like overkill to me. The roof will just tower above the rollbar.
On the factory World Cabs, the roof line is raised 3" in the back to allow for rear troop-style seating. You can see two guys sitting in the back in the advertisement below. But note how little headroom they have. Eric is right, the WC roof line is already 3" higher in the back than say, the Scrambler half-cab roof.
As I'm sure you know, I have jump seats in the back of mine (photo below). These seats are actually lower than the factory troop seating, so I've got more headroom at my jump seats than the guys in the ad below. And even with the more room I have, headroom is tight. My son Alex, who is now 6' 5" (!) has trouble sitting back there now. The factory seats actually are on top of the wheel wells, my jump seats are about even with them.
Now to my Safari-X roof (let's drop the term xTerra), the kick up in the back on my drawing is only an additional 2". So yes, it's 5" higher than the Scrambler half-cab, so it is pretty tall. Is it too tall? I don't know. BTW it's made worse by the narrowness of the Jeep body - at 59", the Jeep CJ is much narrower than the xTerra, for example. I did post a rear view, in the drawing of the Safari-X roof on the LJ, the rear view would be the one where the height would look most exaggerated due to the narrowness of the body, check out that view.
attachment.php
Bingo, that's it exactly. I think that your rear view shows the portion above the drip rail as less visually imposing that it would actually be in person because of the lightened reflection that you have on the curve. I'm just imagining that over my World Cab and it's going to look kind of like a top hat I think.
On the Land Rover Discovery, they avoid the what I think you mean by the "top hat" look by having the rear door go way up into the roof panel. Notice how tall this roof panel is? And yes the LR is much wider than the 59" Jeep.
attachment.php
Exactly, that's the kind of thing you'd have to do, but I don't see it working well with the setup you're going for here and on the narrow CJ, that tall door would start to look like the back door of a slide-in camper :)
If there's a way to work a taller door in somehow, that could be a nice compromise, I don't doubt your creative abilities for a second!
Obviously I'm in the minority and I've already said that I'd love to see it done regardless. I don't want to come across as bashing the idea, just pointing out things based on having looked at my WC for a while.
Yes I saw those seats before. I was more worried about leg room with them. Did you grab them from another truck or are they "Jeff built"? I know you recovered them.
