- Biloxi
- MS
Finished up the 4:1 gear install in the Dana 300. I was able to remove the idler gear (the reason why you have to notch the case) with some very gentle prying with a screw driver. You might want to make your notch slightly larger.
Picture of the internals one last time.
Checking the end play on the output shafts. The rear was fine, but I had to re shim the front several times. The sealant I was using on the shims increases the overall shim thickness, resulting in too much end play. Took several times to get the end play correct. I have .002 end play, within the .001 to .005 range. A little on the tight side, but these are also new bearings.
And fully assembled.
That's it for he 4:1 gear install.
Before I took the transmission apart, I was playing around with it. It has much shorter/tighter throws when compared to the factory shifter
You can imagine the fun I had trying to fish the detached float from inside the tank
