- Biloxi
- MS
Some more T5 information/rebuild updates from the past few nights.
Quick picture of the 5th gear parts/shifter assembly that are concealed behind the rear adapter housing.
And the two T5's reassembled, but not yet sealed up, and minus the shifter assemblies.
Standing the T5 up vertically to measure main shaft end play. This is my "spare" T5. It had 42 thousandths end play, added 3 thousandths for bearing preload, total shim stack behind front bearing race equalled 45 thousandths.
The two top threaded holes on the front of the spare T5 transmission case had weak threads. When I torqued down the front bearing retainer, the threads pulled out. These are 8mm threads, but I used 5/16 Helicoils to repair these holes.
And the shift cover installed. I installed this initially before realizing someone took the shift fork/rod assembly apart and put it back together wrong. I did not realize this until I went to install the adapter housing. Had to pull it back apart, take the shift fork assembly apart, and reassemble correctly.
Once the top cover issues were resolved, I dry fitted the remainder of the transmission, i.e. the rear adapter housing and shifter parts. I shifter through all the gears, and it works.
One thing I will say about the T5's compared to the T176's, they are very "fiddly" to reassemble. I have spent a good bit of time dry fitting up parts/assemblies and making sure they work before sealing them up. There are lots of little tricks/techniques to putting these back together that you need to figure out as you reassemble. The good thing for me, I figured out all these tricks on the first T5 rebuild, so the final assembly on the second T5 should go quicker.
That's it for now.
That's it for now.
