- Dexter
- MI
Anybody having trouble using iphone Tapatalk app? I can't access the web page from there. Trying to upload pics from my phone.
You have to be a paid supporting member to access the forum with Tapatalk now.
Is it me or is your P/S pump at a severe angle? Don't know if that matters but if its runnin' steering AND brakes you may want to keep the fluid in it?![]()
And believe me... I FEEL YOUR PAIN with moving! I'm stuck in Germany and pay storage for 2 Jeeps! No "free" place to work on any of them so that costs a bundle too! Can't wait to get back stateside! My poor Scrambler hates me since I haven't touched it in months other than to store stuff in it! haha!
Looking good on the build! Can't wait to hear that beast crank up!
PERFECT!!!!!!!!!!!!!!!!!! Those mesurements will get me going. I started driving the bread truck back and forth to work on monday just to be sure there are no hidden bugs in it, We have been going out at night and putting about 30 miles per trip on it every eve as well.
I was going to try and keep the tcase were it is now located in hopes of using the stock drive shafts at least until i rip them out. You dont know if your tcase is close to it original location?
I ordered my bellhousing and trans and a clocking ring this morning and when they get here I will be right behind you.
This trans is supposed to have a twenty three spline gas output shaft so the guy said with a clocking ring the t case should fit fine. He said the clocking ring takes up space so he would not have to cut length off the out put shaft. Did you have to shorten your output shaft?
I didn't use the clocking ring and my output shaft was for a diesel (dodge). It mated up perfectly. You can see in the pics that the D300 is turned down more than usual but I have no problem with it's placement other than aesthetic look. I might have an issue with the D300 shifter, but I broke mine anyway so I'll be building a new one. I also turned my engine a couple degrees to it's left (looking forward from the drivers seat). This gave me more clearance between the driveshaft and the oil pan. It does bother me the way it looks though. I have the manual for the cummins 4bt and I also went to the cummins dealer and ordered a parts catolog for my engines serial number, that way I know I am ordering the right part for the right year. It was about 50 or 60 bucks but worth it to me. I can email you the 4bt manual. It has all you need for installing, wiring, adjusting, etc.
So what was your spline count on the tranfer case Twenty three??
I'm pretty sure mine was 23. It's all mated up now. The Dana 300 is 23 so it has to be 23 on the NV4500 output shaft. I was curious about the clocking ring if I ever decided to put one in would I have to get a longer output shaft or not. I guess I'll cross that bridge when I get to it.
