Of course, I was missing part of the shifter linkage. I was missing the shift shaft and two of the bushings.
You have to install these parts before you bolt the transfer case to the adapter. Luckily, my good buddy Chuck had the parts I needed. Thanks again Chuck.
Next, I installed a new seal in the adapter housing. I used the following seal, it was a match for the National Seal that was in there. I like this seal better, it is a "double lip" seal. This seal is very important. There is no rear seal installed in the back of the 700R4. This seal is all that keeps the ATF from leaking past the output shaft. Actually, fluid will leak past the output shaft. This seal keeps the fluid from going into the Dana 300 side of the adapter.
The seal installed. I used some sealant around the outer edge of the seal. I also greased up the seal lip. This picture shows the back of the adapter that bolts to the face of the Dana 300. Note the large o-ring seal that seals the adapter to the face of the transfer case.
This picture shows the front of the adapter, that bolts to the 700R4. Note the "square" o-ring that seals the adapter to the transmission
When you bolt the adapter to the transfer case, these number must be at the top, or the "clocking" will not be right.
I would also like to give a big THANK YOU to NOVAK. Even though I did not buy this adapter from them, I contacted them about it. They were very helpful. They went back and looked through their archives, since this is an older/no longer produced adapter, and emailed me the instructions, and offered to answer any questions that I may have. If I ever need to buy an adapter, I know who to go to. Top notch customer support, even though I was not a customer. A huge THANK YOU to Novak, highly recommended.
I then bolted the adapter to the transmission. Easy enough. The fun part, bolting the Dana 300 to the adapter. The adapter fits super, super tight around the 300's input shaft retainer. The holes in the adapter that line up with the transfer case studs is also an exact/precise fit. These two facts, coupled to the fact that their is a very important seal installed in the adapter, which would be easy to knock out, ruled out the old "bench press the transfer case back in" install method. I tried this, and failed.
So, I put the transfer case on a floor jack, raised it to position, and got the transmission output shaft to spline into the transfer case input shaft. I had to shift the t-case to 2wd, so I could get the spline to line up. Once the splines were engaged, I put the t-case back in neutral. Now, all this time, the splines are barely engaged, maybe a 1/4". Once back in neutral, I rotated the transfer case to the correct position, and gently shoved it forward. It stopped when the transfer case input shaft housing met the adapter. Once I verified the alignment, I gently pulled the two units together using two slightly loner bolts. Like I mentioned before, the fit between the adapter and the input shaft is super tight, you can not shove the two together. After gently pulling the the two together, i installed the correct bolts/nuts.
The re-installed transfer case.
Picture from the top, note the numbers are at the top.
Now, after reinstalling the transfer case/skid plate, I did some head scratching. I do not like how the PO lowered the skid plate. But, there is not much choice. The size of the transmission (depth) almost dictates this. Also, if the skid is not lowered, the transfer case would hit it. While I don't necessarily like this, for now, I am going to go with it. Once I get the Scrambler running, I am going to revisit this issue. The engine needs to be sitting at about a 4 degree down hill slope. I am not sure where it is set currently. Once i get it running, and on level ground, I can do some more checking. I "might" be able to space the entire engine upward, then move the skid plate up, too. No chance of clocking the transfer case with the 700R4, the front drive shaft clearance, as is, will be tight.
Side shot, showing the home made drop. If I have to keep it dropped, i will install a continuous drop spacer, and install the middle bolts on each side.
Rear shot, showing the minimal space between the bottom of the transfer case and the skid plate. Also, note the minimal exhaust clearance. I might just have to live with the drop, unless I want to reinvent everything.
Picture showing clearance between the transmission pan and the skid plate. No room for a fancy, deep pan. The current pan has a drain plug, so I will probably keep it. I plan on dropping the pan, changing the filter, and installing a Lube Locker gasket. I will probably also install a temperature gauge sending unit port in the side of the pan, too.
I still need to bolt the transmission mount down to the skid plate, too. And also, probably, need to install some type of "torque mount" similar to the factory deal. In one of the above pictures, you will see the piece of steel bolted below the transmission mount. I will probably weld a flat 1/4" plate to the bottom of this, then bolt this plate down to some of the existing holes in the skid plate.
