Switching gears from painting to plumbing.
I was not too happy with the current fuel supply/return set up. The fuel pump was mounted near the front spring hanger, the return line was "t'd" into the supply line right in front of the electric pump, generally, just didn't like it.
My new plan:
Mount pump on rear cross member (the one that holds up the front of the fuel tank)
Run new supply/return lines down the passenger side frame rail (on this engine, the supply/return pickups are both on passenger side, right in front of the motor mount)
First up, taking off the old fuel supply line. The blue tape shows where I plan on cutting the line. I am going to reuse a short piece of the original line, from the tank to the cross member. The 3 lines that pass over the cross member and go to the back, are secured by a hidden clamp. There is a bolt that holds the clamp down, in the below picture the wrench is on it. It is very much fun to loosen/tighten!!!
Quick picture of the old plumbing removed. Note the "T'd" in return line.
And the easy part cutting, the old line and flaring the end. This short piece of line will tie into the rubber supply line on top of the gas tank, then pass over the cross member, then turn 90 degrees toward the passenger frame rail. I will tie my filter/pump at this point.
Quick picture of my new lines next to the original. In a "lack of planning moment", I only bought 8' long pieces of tubing. This will work, and the hard lines will end right at the front spring hangers. In hind sight, I wish I would have bought 10' long pieces of tubing, this would have brought the hard line almost to the engine mount, and would only require approximately 6" pieces of rubber line. With my 8' pieces, I am going to have to run 18" long pieces of rubber line. Not the end of the world, but hind sight is always 20/20. The tubing I purchased is .035, stainless. I bought it from a local hydraulic/pneumatic repair shop.
The factory supply line has the weird "bump out, go around, then go back to the frame" bend. This is to clear the old style, full bodied shocks. Since I am running newer shocks, with only the "shiney rod" passing next to the frame, I do not need to make this weird "clearance bend".
And the most frustrating part, making "flared/bump out ridges" on the ends of the metal line to help secure the rubber lines. I should have learned my lessen with this when I was messing around with my lines from In Line Tube on the red Scrambler - typical POS flare tools will not touch SS tubing, easily!!!!
After about 4 hours of frustration/cursing, I was able to make some "flares" on the ends of the lines. In hindsight, I should have let the hydraulic shop do this. Not the pretties job, but it will work.
I need to clean all the old grease/oil grime off the frame rail, then start mounting up these new lines. I am going to start at the back, and work forward. I am going to bend them as I go, so lots of "off/on/mock up/take on/take off" to get them how I want them.
I also plan on cutting off a short section of the original hard return line, and rebending it to face the passenger side frame rail, much like I did with the original supply line. Since the original return line is on the driver side, and runs/secure with the vent and rear brake line, I will most probably cap the ends of it, and "abandon it in place". If I remove it, the factory clamps will not secure the other two lines too good.
Once I get finished with this plumbing work, then I can work on getting the engine fired up!!!
That's it for now.
