Ok, back on topic!!!!!!!!!!!!!!
Installing the Dana 300 to the AX15 using the Novak Clocking Ring
I will let the pictures do most of the talking. I took the pictures as I was experimenting, so not everything is in as good as order as it should be, bear with me.
The Novak clocking ring comes with 4 sets of holes, 0, 9, 18, and 27, with 0 being flat and 27 being angled down.
The O degree rotation will not work without major shifter modification, and maybe even floor board modifications.
Picture with the studs at the 0 degree setting. I did not even attempt to install it like this.
Up next, I tried the 18 degree set of holes. No reason why I tried this setting next, I just did. Picture with the studs at the 18 degree setting.
Quick picture showing the gasket, loosely fitted. NOTE - it will only go on one way!!!!!!
A picture of the transfer case strapped to the jack, studs in the 18 degree setting.
Hmm, at 18 degrees, the transfer case wont slide all the way in.
And this is why, the stock Dana 300 shifter holder thing is fouling on the AX15 case.
I "think" you could get this 18 degree setting to work, but it would require some grinding/trimming of the shifter bolt support thing.
Up next, lets try the 27 degree setting, the most angled setting.
Studs installed at the 27 degree setting.
And it wont work with the 27 degree setting, the shifter support hits hard. You would have to completely cut off the inward support arm.
Ok, so the 0, 27, and 18 degree setting will not work, without modifications. So, lets try the 9 degree setting.
Studs installed at 9 degrees.
