Anyone moved their ignition control module?
Google "stealth HEI"
I agree, HEI module is the way to go, and doing the stealth HEI allows the original appearance, mounting location, and plugs.
Nice idea!
http://www.junkyardgenius.com/ignition/jeep/HEI01.html
You're right. #WWBWD? Now we're trending... Great idea about the stickers and shirts!
Would the t-shirts have pictures of things BW would do on the front and pics of things he would drink on the back?
I know everyone is all about some HEI in this thread but has anybody opted for the TeamRush + CDI instead? I picked up a Summitt CDI module and am in the process of buying the new cap, cap adaptor, and button. I'll probably go ahead and throw an MSD blaster coil on there, too.
I looked hard at both and decided in the end that three was no real difference in performance either way but the HEI is literally one wire and therefore cleans up better under the hood. Only difference I could find and used that to break the tie for my thinking. :shrug:
Jeephammer on the jeepforum would say different, but as you say there probably won't be any real difference. HEI seems like the better choice for those of us that just want to turn the key and go.
Pretty interesting read:
http://www.ifsja.org/forums/vb/showthread.php?t=19440
I have HEI in the TBI 350 Tan Scrambler and Duraspark in the 258 Green Scrambler. They both have components that will fail, and leave you stranded:twocents: I keep spare ICM's in each vehicle:twocents:
My Green Scrambler, that has the stock feed back Carter and stock Durapark runs fine. The factory ICM finally melted a few months back.
I got bored, so I ordered up the "Team Rush" parts from Advance Auto today, will do the deed this weekend, and report back. I am going to install (with Advance Auto part #'s):
1) Distributor Cap - C193
2) Rotor - D219
3) Cap Adapter - C193AP
4) Plug wires - WR4050
5) MSD Blaster 2F coil - 8205
Not exactly "cheap", about $150.00:twocents:
I like the idea of installing the MSD 6A ignition, it would probably be a good investment, but more $. Maybe in the future:thumbsup:
I like how you can wire up the MSD, and leave the stock components in place. With a few simple plugs, you can swap back to the stock set up, if the MSD ever fails:twocents:
When I went to the one piece nose on my Jeep I had issues with burning up the modules because I put it too close to the exhaust on the firewall. I move the module inside under the dash by the steering column and it stayed there for over 10 years until I did a motor swap. It even had enough wire from the stock harness to get it to the new location.
I am at 135,000 or so miles on the original stock ICM with no problems. Now that I post this, I am going to go put my spare factory ICM into the Jeep. :-)
2) Rotor - D219
That's exactly what I did, but if the MSD fails, I have absolutely no recollection of how the original ignition was wired. All the parts are there, but I better be around some of you guys when it happens.
Well aware of his thoughts. Maybe if you had an otherwise brand new setup there would be some minimal difference but In a real-world CJ, I simply do not think there's a practical winner.
:eek: leave all that there and add more to the engine bay? I like spares for what I have vs entirely different setups and requiring more potential spares.
I'll take my one wire, spare cap and module :thumbsup:
Of course this is all from a guy who put in a 4.0 :rotfl:
But for the record if I had a stock-ish CJ I'd now do the HEI and MC2100 as my default setup.
I like the HEI module because they are cheap so you can throw an extra one or three in the console.
After reading the comments and spending some time on Google, I think the HEI upgrade is my best option. I like the idea of cleaning up the stock wire mess, and the simplicity of a one wire connection. Plus, my Scrambler will never see any extreme conditions like water crossings or bouncing around on rocks. It spends it's time going to little league games and puttering around the city.
Thank you all for your input!
I said that based on the information found on the internet.
I could be wrong, but it seems like a lot of people feel the HEI ignition system to be better than stock, but less effective than other systems that are available.
When I started searching for information on the HEI upgrade, I found an overwhelming amount of articles, blogs, and forums discussing ignition upgrades. For every suggestion, there was always someone with a contradiction and counter suggestion. "HEI, TFE, MSD,"...it's a lot for a non-mechanic like me to take in.
Sorry if my statement offended anyone and thanks again for your help!
Allan
