Adam, just curious what brand your rear bumper/tire carrier is. It looks good. I'm trying to decide if I'm going to use factory swing out tire carrier or go the route you did. Either way I'll have to get a new rear bumper
Adam I don't think there is many trans experts here. I had the same problem, and still do, but not as bad. Have you set your "Kick Down" at full Throttle (with engine turned OFF!)? Seems the more I adjust it the better it gets, then I loose everthing trying to get it just a little higher. I am by no means a trans guy, just a Jeep tinkerer.![]()
Like I said, by no means am I knowledgable on these. I was told to hold throttle wide open , with engine off, and on the end of the kick down cable there is an adjuster that is spring loaded and you squeeze it and now your kick down is adjusted. That simple.
Now they may have been pulling my leg, but when I squeezed it it moved about an inch and poof! My Trans started working correctly.
I have a TF999 to swap into one of my '7's at some point, so while I don't have any hands on with one yet, I have done a lot of reading on them.
Here's a good series of videos on rebuilding one, and gives some insight on the innards.
https://www.youtube.com/watch?v=xzJhCBZ1wMY
I have read that the bands can sometimes come out of adjustment and cause slipping, and can simply be tightened/adjusted, but sounds like you have something else going on. Will be interested to see what ends up being the problem.
Link is actually for a 727. I'm hoping they are similar because plan is to try to rebuild mine myself....![]()
