IAFFCJ 81 Scrambler
LOL. It takes time to get it to "click". My advantage is that I bend a lot of lines. Actually, that's what I have to do today on a 69 Camaro. :) BTW, you should get a -6 fitting for the hydroboost return fitting. That cleans things up a lot because all of the fittings on the hydroboost would all be -6.
It’s hard to see but I did change it over. Waiting for my adapter to make the return side of the steering Box -6 also.
No ac on this on. Will probably never see a top.
I don't ever close mine in but still running the A/C is fantastic! I'd highly recommend it.
With the return to the PS pump, are you running the 3/4T truck pump with two return lines?
I’ll have to think about the ac idea not in the plans right now but heck they have changed a lot from the beginning.
As for the PS pump. It is the stock pump from the donor vehicle which was a two wheel drive GMC Yukon. I know some suburban were 3/4T but I didn’t think the Yukon’s were but maybe. And yes it does have two returns which is making things easier.
I would at least engineer in the condenser. Once you have air conditioning, you will not regret it. I don't even deal with the humidity that you guys do. Just note to self, you will run out of real estate pretty quickly once you get all that in front of the radiator.
My 2005 Yukon Denali has a hydroboost. :)
AWESOME DAY. JeeperDD came up to help on the scrambler again today and the morning started off with him giving me this.
Holy freaking awesome.
Then we spend all day doing things like this.
TO make pretty things like this.
Which resulted it this.
[video=youtube_share;Ku1Wd6peW18]https://youtu.be/Ku1Wd6peW18[/video]
Totally stoked can't be more exited to get this thing actually moving now. Huge shout out to JeeperDD couldn't have done it without his help.
Nice! Looks like you guys had a great day!
Thanks everyone it is a huge feeling of accomplishment and excitement
I have a ton of little things to get finished up to be ready for the dash to come back from paint. I now have all the wires from each sensor run to under the dash in one form or another. I had to modify the harnesses that came with the Speed Hut gauges to reach the locations I have everything. All wiring in the engine compartment is done I think until I get the ARB compressor so it will be time to move under the dash soon.
Prepping gauge harnesses for install.
Trying to stay on track I kept working in the engine compartment before moving into the cab to keep working on the wiring.
Got the power steering cooler all plumbed and as soon as the one last fitting for the high pressure lines arrives I will be able to fill that system.
As I have been trying to finalize and clean up all the wiring and plumbing i was needing some inner fenders as I was running out of real-estate to mount things. I also needed some form of protection for the computer and throttle module so out came the cardboard.
A few more bolts and some paint and these will be done.
So many of your posts having me looking for the "Like" button.
This one deserves an actual response to let you know people are following even if they don't "reply"
Great fab work!
:bow::bow::bow::drool::drool::drool:
WOW :eek: That power distribution panel is insane, awesome work!
That said, did you look at any of the options out there for accessory power before deciding to go this route? I did something like you for my switched circuits on the Postal but have now looked at enough of the various aftermarket solutions now that I'll never do it again. sPod, S-Tech, Painless, Trigger and a pile of others.
Just curious if there was a decision process to going this way.
We just finished up a Painless Trail Rocker install on a CJ7 at the shop. So clean and easy. However definitely has that “bought” look but saved so many headaches. No way near as custom / cool as the above though
Awesome work. You’re going to get a video of a burnout with those rollers right?
