- Conklin
- MI
Still just doing little details on here.
The skid plate is modified for the deeper pan.
Coolant overflow is done. I had to take the spiral site glass off and replace it with a regular one. There was too much surface tension in the plastic tube and it wouldn't flow the coolant.
I also had to add a relay to the BCM power so it doesn't drain my battery. For some reason it won't go to "sleep mode". The guy at White Auto and Media that programmed my instrument cluster won't reply to emails............so this is my "temporary" solution.
