- Cave Creek
- AZ
My build is right on the verge of being done, and one of the things holding it up was a zeroed out gas gauge. I was really racking my brains trying to work with the build shop to figure out what was going on. The gauges had been acting up, but even after sorting them out the gas gauge was still reading empty. I had spent an entire weekend earlier this year cleaning the tank, painting it, and checking the resistance of MTS sending unit before installing it...and then double checking it again after it was installed, so there's no way it could be the sender, right?
Well folks, PSA - don't mock a tank up unless you expect to have gas in it soon. This is what your sender will look like after ~10mos, even in the dry southwest with the tank able to vent. The brass float I used to replace the plastic one had deteriorated, even, it was full of gas. The whole thing looks nearly as bad as the 30y/o one I replaced with this one. Maybe this should be in the "relics" thread?
At the time, it was a 15 gallon steel tank, probably a Crown/Omix sender. When I pulled the 15 gallon tank out to replace it with a 20, it still looked new. BUT, it had been in "service".
