- Redmond
- OR
Thank you for checking! I already have a drivers side 241c. It’s 27 spline, but I need to tear it down to do a SYE, so I might as well just swap the inputs.Do you have your 241 yet? I checked car-part.com around Oregon, there is one in Portland for $200 B and R auto wrecking (stock #WIH373). That had a 3 speed, so it should be the th400 with 32 spline output. Since its an 89 it would have cable drive speedo, so you would need a pass through VSS to make your engine/trans happy. If you went with a 90 plus it would have the electric speedo output.
I was moving my transfer case “collection” around to make room. I have a 21 spline 231J, a S-10 231C, a PSD 208 32 spline Chev, a DSD 27 spline 241c, a DSD 32 spline 241c, and the one PSD 241c. I might be a hoarder...
