You can try putting that tire and wheel on the rear and see if there is a difference in the rear of the jeep. I've had 4 BF Goodrich all terrain tires have a belt tear in the last year and a half on 2 of my work trucks. On the last 2 the tires had less than 2,000 miles on them. Both were in the front. Took the truck to a repair shop that all so balances. They said tie rods were a little loose and a ball joint was a little loose. Not enough to cause the tire problem but wouldn't align the truck with out the repairs. Got new ball joints, tie rods and tires (2,200. worth) with a alignment. After the work was done had very bad memory steer problem. After 2 trips to the shop and adjustments problem remained. Took the truck to my mechanic (he can't do alignments) and they couldn't see a problem. I finally told my mechanic the trucks not safe to drive and had him replace the ball joints. When I went to pick it up his worked came up and told me it drives like it did before the other mechanic. Another 500. and it's on the road in good shape. What started the problem was both front tires had belts that came loose. At least for my work truck I'm done with the all terrains. Sad to say since I've used them since 2003, somethings happened with their quality. Check the tire.
Yep, I moved that tire/wheel from front driver to passenger rear to passenger front: vibration would come from the corner with that particular tire/wheel assembly. Either that tire is defective/damaged, or the minor bend on the inner side of that wheel. If I was a gambling man, I would bet tire
The tire people swear the tire is fine, but that is also in their best interest.
The independent shop that balanced the assembly the second time said the wheel was bent/excessive run out, causing the vibration.
The wheel repair guy said the minor damage to the wheel is NOT the issue, and it would be in his interest to repair it $$$.
From previous experience with tires that have broken belts (I am looking at you Goodyear MTR's, happened to two sets, one on a TJ, one on an LJ), the vibration I am feeling in the Scrambler is similar.
I could buy 5 new tires and test this theory, but that would be cost prohibitive. I could probably squeeze the 33" tires off the red Scrambler onto this one, test drive, see what happens. I have mentioned before, the tire/wheels on the red Scrambler have not been rebalanced since I purchased them (at least 10k miles), all four wheels are bent, they drive super smooth. Would be interesting. IF the vibration went away, how could I then leverage that into getting defective tires replaced, that would be the million dollar question???
As for mechanical issues on the green Scrambler that could cause this issue, I have checked and rechecked, plus two additional tire shops have checked all of the following, no issues found, and I am sure the shops would love to find an issue:
Alignment - fixed at one shop, verified at another
Wheel balance - balanced at one shop, adjusted/approved at another
Tie rod ends, ball joints, shocks, suspension bushings, wheel bearings (front and rear), driveline angles/balance, front brake calipers/rotors, etc, all are fine, most of these components are new with minimal to zero appreciable wear.
I hate to say it, but I am really being led to believe that it is a tire issue.
The BFG Mud Terrains on my red Scrambler are much smoother than the BFG All Terrains on my Green Scrambler
