The older guy at NTB pulled the tires off the wheels and found no problem with either the tires or wheels. They "RoadForce Balanced" them, again, and gave them back to me. Before they dismounted the tires they checked the balance and said they were all out of balance.
Picked them up/reinstalled them Monday night:
A quick test drive showed a vast improvement in the level of vibration, but there is still some present between 55-65 mph. It is tolerable, but I still do not believe I should be getting this level of vibration from all terrain tires? My tore up/not rebalanced/bent wheel BFG Mud Terrains are smoother than these BFG All Terrains.
If the vibrations continue to aggravate me I will probably just go ahead and bite the bullet and install another set of tires.
