Nice. I'm going to be doing the same thing for my Dana 44/Toyota 8" swap. I'm sick of smacking into my U bolts.The makings of a square u bolt flip kit for my SUA Dana 44 front.
View attachment 105342View attachment 105343
Nothing at allHow much work to the tunnel is required to fit the AX15. I'm drooooooling!
I'm learning as I go. A 12 V 100 AH AGM Battery is needed. The idea is to keep the battery charged until you need it. It powers a 2000 Watt Inverter so you can run110 Volt things such as a refrigerator or food freezer and small appliances. No matter how big or expensive the parts of the system are, things are only going to run as long as the battery lasts. You can add a second battery to the system. The Power Whisperer design allows you to recharge the battery either from 110 if available, or a solar panel (or two), or from the power socket (cigar lighter) in your vehicle. There are 4 breakers so you can choose what you want to work. This diagram used 30, 15, 30, and 5 amp circuit breakers. The later design changed from a 1 1/2 trickle charger to a 4 Amp trickle charger and upped the 5 amp to a 15 amp breaker. I'm using 2 amp trickle chargers with the 5 amp breakers. Had I known sooner, I would have gone to the charger with more amps. The solar panel needs a controller. Pictured is the one that I used. The metal box was made so a roll-up solar panel could fit inside to keep everything together and portable. A 45 foot lead cable for the panel fits inside also. That's the system. You can buy a new one for a little under 3K. You can build one for a lot less.Info on these "solar generators" please....
Thx
That is way cool!! I need one to go with my Scrambler!Got a bit distracted tonight, no transmission rebuild updates. But, I did get my last parts in today so I could build this:
Missing a tooth up front, might need to scavenge a part from the Lego bin.
Is that a kit? If not where did you find plans for it?Got a bit distracted tonight, no transmission rebuild updates. But, I did get my last parts in today so I could build this:
Unfortunately, not a kit. You have to buy the instructions which come with an inventory list, then buy each brick to create the kit.Is that a kit? If not where did you find plans for it?
Thanks. If you need any more info, just ask. Put the batteries in and the cables on today. All done except the latches to hold the side doors shut.That’s nice work right there Kim!
