TravelnMan
- Granby
- CT
Very cool - the battery temp gage had me confused for a minute.
It's rated at 406 ft/lbs and 275 electric HP (which is roughly equivalent to 440 ICE HP). I should get somewhere between 120 and 150 miles of range from the 53kWh pack based on rough math but I'll definitely be doing real world calculations once it's on the road. 120 is plenty for my intended use as a seasonal daily driver and occasional foothills explorer.What is the HP and battery range?
Our other Jeep is a 4xe Wrangler (Hybrid) that we typically run in electric mode. (The range is ~ 20-25 miles depending on the weather and terrain)It's rated at 406 ft/lbs and 275 electric HP (which is roughly equivalent to 440 ICE HP). I should get somewhere between 120 and 150 miles of range from the 53kWh pack based on rough math but I'll definitely be doing real world calculations once it's on the road. 120 is plenty for my intended use as a seasonal daily driver and occasional foothills explorer.
Super jealous of the build, its gorgeous. I love how quickly it came together, I am still working out some of the kinks. For example, I had intermittent charging issues and realized, doh, that one of the screw terminals in the fuse block between the charger and the battery was not tight.It's rated at 406 ft/lbs and 275 electric HP (which is roughly equivalent to 440 ICE HP). I should get somewhere between 120 and 150 miles of range from the 53kWh pack based on rough math but I'll definitely be doing real world calculations once it's on the road. 120 is plenty for my intended use as a seasonal daily driver and occasional foothills explorer.
It does have regen and I'm working with the eGT guys on the tuning of that.Our other Jeep is a 4xe Wrangler (Hybrid) that we typically run in electric mode. (The range is ~ 20-25 miles depending on the weather and terrain)
One thing that greatly effects the range is higher speed driving, as we all know the body is not very aerodynamic.
Does yours have regenerative braking capabilities? That helps as well during stop and go driving.
Keep us posted.![]()
When I was making my own ASTM-grade biodiesel, algea was a relatively new consideration, but the yield was so minimal/not scalable that it wasn't a viable source of oil. Used coffee grounds were another source that fell into the same category.I was waxing a bit lyrical, sorry.
What I meant really was that given methane is a much more potent greenhouse gas than carbon, the fact that one was burning the waste oil rather than letting it ferment into methane resulted in a net gain to the environment. Granted it's all at once rather than slowly being released but it was kind of a fun argument.
Thanks! The electrification has definitely come together quickly, thanks to the eGT systems being as close to "crate" as possible. The downside is the cost, though fortunately for me I'm essentially their guinea pig (and marketing now apparently) for this system so I got a decent break on that.Super jealous of the build, its gorgeous. I love how quickly it came together, I am still working out some of the kinks. For example, I had intermittent charging issues and realized, doh, that one of the screw terminals in the fuse block between the charger and the battery was not tight.
Did you mention the motor details? The numbers are very similar to dual Hyper-9's. I am running a single but already have designs in my head for a second (and it will fit).
Holy hell it's @1x1_Speed_CraigWhen I was making my own ASTM-grade biodiesel, algea was a relatively new consideration, but the yield was so minimal/not scalable that it wasn't a viable source of oil. Used coffee grounds were another source that fell into the same category.
jc_chandler - Absolutely BEAUTIFUL project!![]()
Welcome back!OMG!Holy hell it's @1x1_Speed_CraigWelcome back!
