Scout the Scrambler
Love the build. I would LOVE an electric jeep. It would be awesome to be creeping down the trails listening to nature vs a smelly loud engine. This is also coming from someone who loves V8s and diesel engines.
Love it. Yeah, saw all the negatives on FB. I think it’s a great looking Jeep no matter what provides the motivation.
What is the HP and battery range?
It's rated at 406 ft/lbs and 275 electric HP (which is roughly equivalent to 440 ICE HP). I should get somewhere between 120 and 150 miles of range from the 53kWh pack based on rough math but I'll definitely be doing real world calculations once it's on the road. 120 is plenty for my intended use as a seasonal daily driver and occasional foothills explorer.
Don’t worry a charger is coming soon where you need it. Quiet will be interesting out on the trails.
Our other Jeep is a 4xe Wrangler (Hybrid) that we typically run in electric mode. (The range is ~ 20-25 miles depending on the weather and terrain)
One thing that greatly effects the range is higher speed driving, as we all know the body is not very aerodynamic.
Does yours have regenerative braking capabilities? That helps as well during stop and go driving.
Keep us posted. :popcorn:
Super jealous of the build, its gorgeous. I love how quickly it came together, I am still working out some of the kinks. For example, I had intermittent charging issues and realized, doh, that one of the screw terminals in the fuse block between the charger and the battery was not tight.
Did you mention the motor details? The numbers are very similar to dual Hyper-9's. I am running a single but already have designs in my head for a second (and it will fit).
It does have regen and I'm working with the eGT guys on the tuning of that.
I was waxing a bit lyrical, sorry.
What I meant really was that given methane is a much more potent greenhouse gas than carbon, the fact that one was burning the waste oil rather than letting it ferment into methane resulted in a net gain to the environment. Granted it's all at once rather than slowly being released but it was kind of a fun argument.
When I was making my own ASTM-grade biodiesel, algea was a relatively new consideration, but the yield was so minimal/not scalable that it wasn't a viable source of oil. Used coffee grounds were another source that fell into the same category.
jc_chandler - Absolutely BEAUTIFUL project! 8-)
Thanks! The electrification has definitely come together quickly, thanks to the eGT systems being as close to "crate" as possible. The downside is the cost, though fortunately for me I'm essentially their guinea pig (and marketing now apparently) for this system so I got a decent break on that.
For the motor, it's a single motor and they have kept the manufacturer very close to the vest. As close as I can tell, given the up-close inspection I've done plus the system voltage (750v), it's most likely a Cascadia or something very similar.
750v!! Holy crap. Definitely not a DIY item I would tackle. I'll stick with my 144v.
Holy hell it's @1x1_Speed_Craig :eek: Welcome back!
