- Biloxi
- MS
Getting ready to reinstall the transmission/transfercase/bellhousing assembly. I dumped a quart of oil in the transmission yesterday, it didn't leak out, so gonna say the anaerobic sealant should be good to go.
Assembling the release bearing arm to bellhousing, dont forget the little ball and spring.
And the release bearing installed.
And the bellhousing bolted to the adapter plate.
The Novak instructions mention threading the lower bellhousing bolts into the original threaded bellhousing holes, but not the case with my threaded adapter plate, all four bolts are installed from inside the bellhousing.
Trimming the ridiculously too large OD of a Dana 300 to transmission gasket before installing it.
The AX15 rear case has a weep hole in the bottom. I plugged this up with RTV before, did the same thing this time. If either seal leaks a little bit into the small cavity where the transmission output shaft slides into the Dana 300 input shaft I don't care. I use yellow metal safe gear oil in the Dana 300 so if some cross contamination occurs so be it. No leaks before, hope for the same now.
I used aviation sealant to glue the paper gasket to the Dana 300 clocking ring. I did not want to use RTV again. No real reason to goop the whole face all the way out to the edge IMO.
And a thin coat on the rear transmission case.
