- Biloxi
- MS
Since I was back here, and the driver side caliper piston did not want to compress/spin back in, I installed new rear calipers. I purchased these calipers a year or two ago from NAPA. I need to find the part number, they are for a Ford passenger car rear brake application. The SSBC calipers lasted 15 years, so no complaints. I will send them back to SSBC for a rebuild, and keep them as spares. These calipers are not super common, either.
Installed, fighting with the parking brake cables.......
Ignored the instructions, looked back on my pictures, done.
The parking brake does work, and works well for normal use. It will NOT hold you on a super steep off road hill. That being said, the drum brake parking brake is marginally better, and both are better with stock size tires. It is not too fiddly to get the OEM parking brake cables to hook up to these calipers, and well worth the effort.
Up next.....
Differential cover gasket and Ox Locker shifter cable o-ring replacement. These items are only 15 years old.......
Up next.....
