Didn't get too much work accomplished this past weekend on the transfer case, but here is an update.
General picture of a bunch of parts. The gears/shafts on the left are the new parts that replace the factory parts in the middle. The pieces on the far right (input shaft, output shafts, shift collars, shift forks) are the factory parts that are reused.
Quick Picture of my reference material: FSM, Excellent Jeep CJ Book, 4:1 kit instructions.
A few pictures of my case modifications. This was my interpretation of what the instructions picture. I hope the notch is big enough.
Started the rebuild/reassemble. Removed and installed the new needle bearing in the rear output shaft. This is kind of a pain, unless you have a small slide hammer or a pilot bushing removal tool. Note the depth of the bearing, it does not get drove to the bottom of the cavity.
Time for the press. After placing the correct gear/shift collar on the front output shaft, I pressed on the front bearing. NOTE - The front bearing of the front output shaft is slightly smaller then the front output shaft rear bearing. Make sure you put the correct bearings in the correct spot. You can press this bearing on while the shaft is out of the case.
I then placed the front output shaft assembly inside the case, put the large gear on the shaft, and pressed on the rear bearing. This is when having a helper is handy. It is kind of a pain to hold the parts in place, keep the case out of the way, and press the bearing on with only two hands. NOTE - DO not put any pressure on the case. You are pressing the bearing on the shaft, not pressing anything into the case. Due to the size of the gears, both factory and 4:1, you must position this assembly in the case before pressing the bearing on. Note how the shaft is on the steel plate. You are pressing the bearing on the shaft. Support the shaft independently from the case. You are not pressing on the case itself. The blocks of wood are to hold the case in position out of the way. DO NOT PUT PRESSURE ON THE CASE.
Time for the inner bearing on the rear output shaft. Again, you are pressing the bearing on the shaft, not pressing anything into the case. Due to the size of the gears, both factory and 4:1, you must position this assembly in the case before pressing the bearing on. Note chunk of steal underneath the shaft onto which the bearing is being pressed. The blocks of wood are to help hold the case out of the way. These shafts/gears/bearings are just free floating inside the case, not bearing on it.
That is all I accomplished. The rest of the parts can be assembled with hand tools, no more press, if I remember correctly. I did not exactly outline all the parts that must be placed on these shafts before pressing the bearings on. Make sure you put all the parts on the shafts before pressing on the corresponding bearings.
That's it for now.
