- Galivants Ferry
- SC
10 4
10kQuestion 38:
Getting close to buying a winch
Most likely will be a Warn evo, may step up to next level if needed.
My question is will the winch perform better with a higher weigh load than needed?
I believe an 8000 lbs would be minimal, 10000 lb is what most people buy. But.. if you went to a 12k would the winch be under less stress and creating less heat and battery load.
That looks about right portionally. I'm running small tires so probably will stay with stock bumper
My 84 also has the fifth character E. Also was originally an auto.Question 40
The 1982 Scrambler i just purchased has the Vin# IJCCE88EOCT
The 5th character is for transmission, my notes do not list an E, only B A M N
I know that it was a 6 cylinder automatic. What am I missing?
@Kim Dawson is correct… Try this decoderQuestion 40
